lincoln auto idle problems
发表于 2021-8-31 22:04:14 | 显示全部楼层 |阅读模式
i have a weldanpower 225 ac/dc  i had the circut boards rebuilt by innovac inc.  new brusches, plug  i checked  idle transformer  but still cant get the auto idle to work right  i use the grinder takes like 3 to 5 sec. to idle up  and when striking an arc wont  idle up i even turned off the switch will dled but when turned on it will idle down when welding.  the only thing i have not changed is the capacitor will a week capacitor affect the auto idle does anyone know?
Reply:Try putting 12 volts from the battery to the throttle solenoid. See if it pulls in quickly.Unplug it from the harness first. Which capacitor are you asking about? Looking at the diagram I don't see any capacitors in the solenoid circuit.
Reply:Originally Posted by gh45ver. . . i checked  idle transformer . . .
GMT+8, 2026-1-3 05:10 , Processed in 0.104075 second(s), 18 queries .
