Looking for some help/advice here, yes I know there is not alot of info here, but I have not called the seller and asked anything yet, going to take a look later on in the weekBut knowing the skill and the experience that is on this site I am sure there is some input to be made. This being a first project and having little expericence working on this gear.....(I am an Elevator Mechanic by trade) what am I looking for or not looking for, and so on.Lincoln 200 SA "Redface" portable welder:-4cyl gas driven-300 amp max true DC outputRuns excellent, but will not weld for some reason, do not have time to fix it. Bought this welder to fully restore, because they are somewhat sought after by pipeliners, but have no time to spend on it.Phone: Kyle 204-383-XXXX asking $600.Thanks in advance for your inputLincoln 175spLincoln 350MP
Reply:I paid $200.00 for a 1966, same condition. Had it welding in 15-minutes. Brushes were stuck. Attached ImagesDont pay any attention to meIm just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:That a shorthood beside it?Deereman75 from TBNLincoln electric AC225SBlueshield O/A torchSmiths aircraft torchCH 3HP 220V air compressorlots of power toolslongevity stickweld 250
Reply:Yes it is. Attached ImagesDont pay any attention to meIm just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:does there happen to be a blackface in your collection?Deereman75 from TBNLincoln electric AC225SBlueshield O/A torchSmiths aircraft torchCH 3HP 220V air compressorlots of power toolslongevity stickweld 250
Reply:Well sure there is! Attached ImagesDont pay any attention to meIm just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Bought this welder to fully restore, because they are somewhat sought after by pipeliners, but have no time to spend on it.HUH? What kind of restoration were you planning?Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:I work with some SA fanatics and from what I've heard most the time if you take one of those big, rectangular pencil erasers to the exciter while its running will fix it. Sometimes just the exciter needs to be cleaned. I'd pick it up anyways, chances are if you cant fix it you could probably sell it and make your money back. Just my two cents. |
