Best material thickness gauge for floor pans
发表于 2021-8-31 22:04:07 | 显示全部楼层 |阅读模式
Redoing the floors in a 1995 Ford f 350.  Is 18 gauge about right?  Is it possible to also strengthen the mounts?HH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:Originally Posted by ckobeskoRedoing the floors in a 1995 Ford f 350.  Is 18 gauge about right?  Is it possible to also strengthen the mounts?
Reply:18 Ga and you can use hat channel to reinforce.The hat channel can be found by the steel studs at a lumber yard that sells steel studs.
Reply:Fantastic idea with the hat channel. I assume it should be placed where the cab mounts need reinforcement Originally Posted by gmakra18 Ga and you can use hat channel to reinforce.The hat channel can be found by the steel studs at a lumber yard that sells steel studs.
Reply:Sure that should work.
GMT+8, 2026-1-3 05:05 , Processed in 0.094858 second(s), 18 queries .
