Harris wire?
发表于 2021-8-31 22:04:07 | 显示全部楼层 |阅读模式
How does the Harris wire compare to Lincoln or Hobart wire??
Reply:Harris is a sub brand of Lincoln. the Harris Magnum Regulators came with Lincolns welders for a little while and they are connected. If you use a Lincoln mig welder, use the lincoln brand. If you use a hobart/Miller use the hobart wire. Lincoln Electric wire is cheap and can be found almost anywhere. I have actually seen it at a Gas station. However harris is a well structured brand!VictorPraxairAir LiquideMillerLincoln Electric
Reply:Originally Posted by IslandWeldingKidHarris is a sub brand of Lincoln. the Harris Magnum Regulators came with Lincolns welders for a little while and they are connected. If you use a Lincoln mig welder, use the lincoln brand. If you use a hobart/Miller use the hobart wire. Lincoln Electric wire is cheap and can be found almost anywhere. I have actually seen it at a Gas station. However harris is a well structured brand!
Reply:jarfly Originally Posted by jarflyHow does the Harris wire compare to Lincoln or Hobart wire??
Reply:Lincoln bought both Harris companies - the gas apparatus co. and the brazing-soldering alloys co."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by OldendumLincoln bought both Harris companies - the gas apparatus co. and the brazing-soldering alloys co.
Reply:i have never used anything bad from harris or lincoln. i have used rods from hobart that werent great.though i havent used much harris welding wire, i have used lots and lots of their BCuP 15 brazing rod for refer and med-gas stuff and it is the best.bosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:I have legacy Harris 308L wire in 25 and 30 lobs spools, made in USA.  Never used, pristine condition.  I'll never use enough SS wire to justify tapping those spools, particularly when I have lots of 2 lbs spools on hand.  I've used a few of their 2 lbs spools as well as their legacy 1 lbs aluminum spools.  Fine stuff, IMHO.Jerry30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
GMT+8, 2026-1-3 05:11 , Processed in 0.093061 second(s), 18 queries .
