查看: 20|回复: 1
tig filler rod holder tubes?
发表于 2021-8-31 21:55:44 | 显示全部楼层 |阅读模式
Does harbor frieght sell tig filler rod holder tubes?I can't seem to find them on their website... only arc rod tubes.. http://www.harborfreight.com/welding...per-46477.htmlcoulda sworn I read somewhere... they sold them Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:Not sure.  But making your own out of PVC pipe is very easy.  I know I have seen posts of some very nice home made ones. Dan D.Manipulator Of Metal
Reply:You can make a whole lot of tig rod holders out of PVC pipe and end caps for not much money.
Reply:thanks!Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:johnt, You should start a welding progress thread.lets see it some dimes lol
Reply:Originally Posted by motolife313johnt, You should start a welding progress thread.lets see it some dimes lol
Reply:Originally Posted by motolife313johnt, You should start a welding progress thread.lets seeit some dimeslol
Reply:Here are mine.  I like the gray conduit tube.  I made sure to make an emergency fire escape for the short stubbies that like to sink to the bottom!  They can't hide now! 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Trying to figure out what is wrong with the tube they're sold in. I can see the type of filler rod and they are labeled?gregMagazines have issues, everything else has problems
Reply:Originally Posted by pepiTrying to figure out what is wrong with the tube they're sold in. I can see the type of filler rod and they are labeled?greg
Reply:Originally Posted by OscarHere are mine.  I like the gray conduit tube.  I made sure to make an emergency fire escape for the short stubbies that like to sink to the bottom!  They can't hide now!
Reply:Originally Posted by HT2-4956OK, here you go.
Reply:I purchased Rod Gard tubes in the past. They're a little more than PVC but I liked the screw on cap and rubber seal. Easy to grab out of the rack and take on the road too. The PVC deal is the best way to go on a budget. I'll likely do it since the dynasty is gone.Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:i use rod guards, but pvc would work.as to the question of grey pvc, it typically, if not always, means it is sch. 80. white is sch. 40, which is thinner. conduit is always sch. 80 where i come from, so the electrical section of home depot will give you that.the plumbing section will give you sch. 40, if you so desirebosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:Originally Posted by duaneb55Looks cold - need more amps!
Reply:+1 on the Rod Guards. weldingsupply.com has the best price.A few weldersA lot of hammersA whole lot of C-clamps
Reply:I don't use that many different filler rods......half a dozen or so. I also cut them down to 18" for ease of storage and handling. I came across these tonight......wonder if you can make them cheaper out of PVC?https://weldingsupply.com/cgi-bin/sp...G-200-24
新手上路
Rank: 1
发表于 2021-8-31 21:56:31 | 显示全部楼层
047Last edited by rahtreelimbs; 10-06-2016 at 10:52 PM.
Reply:Originally Posted by N2 WeldingActually that would make a good sticky.  People could post up pictures in one thread.  Then everyone  could see others improvements and discuss what it takes to get proper looking weld joints that are not only visually appealing but strong sound welds.  It could make for good some good discussions IMO.
Reply:I cobbled this material from work. Aluminum 2 x 2 x 1/8 square tube and plastic caps. I cut these at 20" because I cut my filler rod in half. I put a small knob on the one end to masked these easier to open. Total cost was about $8. I will give them a try. Also square won't roll.
Reply:I take it the PVC/Conduit ones are 2" or 2.5" diameter?RGL Motorsports #129RL Ironworks - Random side stuff....
Reply:Originally Posted by 7A749I purchased Rod Gard tubes in the past. They're a little more than PVC but I liked the screw on cap and rubber seal...
Reply:Originally Posted by John TOrdered a few rod gards. I like the rubber seal / cap. price wasn't bad either.
Reply:PVC, my opinion, is way better than the Rodguard tubes. 2' lower section with slip/male NPT and 1' upper section with slip/female NPT fitting. Virtually indestructible, no rubber gasket to loose, or dry out and break, and costs less than 25% of Rodguard even if you actually  buy pvc pipe which short scraps are usually limitless and free.
GMT+8, 2025-12-17 11:07 , Processed in 0.094719 second(s), 18 queries .
