Anybody have a battery charging station for cordless tools. Inside vehicle?
发表于 2021-8-31 15:01:45 | 显示全部楼层 |阅读模式
Anybody got a system to charge batteries inside their vehicle, perhaps off an auxillary battery.  How to do.this and what would I need? My tool and battery inventory has grown considerable and i need a way to charge batteries while mobile.  I did have a 12v charger for my 18v.nicad batteries. However that was a single battery charger
Reply:I have never had much luck with the longevity of 12 volt DC cordless chargers. May be easier to do a inverter than use standard 120 volt chargers.
Reply:Thanks, that is the way I want to go.  However I want an auxillary battery.  A couple of my chargers have fans in them.  I suspect they pull significantly on my battery if left charging.
Reply:Originally Posted by tapwelderThanks, that is the way I want to go.  However I want an auxillary battery.  A couple of my chargers have fans in them.  I suspect they pull significantly on my battery if left charging.
Reply:I put a 300 watt inverter under my back seat. I just plug in the ac charger. I have fully charger 2 batteries before starting the truck without issue.
Reply:Originally Posted by tapwelderAnybody got a system to charge batteries inside their vehicle, perhaps off an auxillary battery.  How to do.this and what would I need? My tool and battery inventory has grown considerable and i need a way to charge batteries while mobile.  I did have a 12v charger for my 18v.nicad batteries. However that was a single battery charger
Reply:Thanks guys.  I will try an inverter.  When only had 2 batteries it was easy to keep them charged before leaving the shop.
GMT+8, 2025-12-17 10:48 , Processed in 0.334217 second(s), 18 queries .
