Miller cst 250 wiring
发表于 2021-8-31 15:01:44 | 显示全部楼层 |阅读模式
Just bought a used miller CST 250. It came with four prong cord but had 3 prong plug. The wires used were white, black, and green. Im confused as to the correct wiring inside the welder. It seems as though the previous owner used the white neutral in place of the red hot. What do i do here
Reply:theres no common here.       black and white are for hot in single phase,  leave the red out.    add  the red as a hot for thee phase only.    green is ground
Reply:as 123weld said.Section 3-12 in the manualhttps://www.millerwelds.com/files/ow...O2237H_MIL.pdfEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-18 08:56 , Processed in 0.091274 second(s), 18 queries .
