Optrel Crystal 2.0
发表于 2021-8-31 15:01:42 | 显示全部楼层 |阅读模式
I just made a purchase for a new welder and had the option of getting an Optrel Crystal 2.0 for an awesome price so I went ahead and made the purchase blindly and looked it up after the fact. I like the looks of it and wanted to get some real world feedback from people that have it and or have used one. Do you like it? How much better is the clarity and color? I have seen a couple people say that it is brighter and had to shade it a little more than normal.Any input would be appreciated!
Reply:I have that. Great clarity, quality problem. Pay attention to the flickering red LED light when you are grinding so that you don’t get flushed when you switch back to welding. Sent from my iPhone using TapatalkHTP Invertig 221H w/ CK20 water-cooled torch  •  Lincoln PowerMig 210MP  •  Hypertherm PowerMax 45XP  •  Optrel Crystal 2.0
Reply:What quality issues have you been experiencing?
Reply:None. This is a high-quality well executed Product. I think of the concept of “quality” is not assessed the same way at that level of engineering and execution as one  would have with the Harbor Freight type stuff commonly discussed on forums. That said,  I think that there are personal preferences such as comfort of the headgear, which some people have mentioned on various forms. I did not experience that problem, so I can’t comment. Sometimes the headgear can be loose when the helmet is lifted so you need to tighten the band a bit. Sent from my iPhone using TapatalkHTP Invertig 221H w/ CK20 water-cooled torch  •  Lincoln PowerMig 210MP  •  Hypertherm PowerMax 45XP  •  Optrel Crystal 2.0
Reply:Originally Posted by koenbroI have that. Great clarity, quality problem. Pay attention to the flickering red LED light when you are grinding so that you don’t get flushed when you switch back to welding. Sent from my iPhone using Tapatalk
Reply:Haha, ok, all good! I was hoping there wasn't a quality issue with it but you never know...Thanks for your review. Mine should be here this Friday or next Monday and can't wait to try it out!
Reply:Sometimes it's about the environment too.I had a super busy Summer last year, and was skipping between welding, and working in the field,,,,,,or trying to work in the field.  Was the reason for all the welding.Anyways...….usually I put my hood up in the house when done.  Air conditioned.Last year, I just hung the thing by the door, on the air manifold from the compressor...….and left it out there overnite for days on end.  On top of this, it was extremely hot, and I had a lot of sweat dripping inside the hood when working.Long story short...…………………………………..The dam spring that holds the batteries in place corroded.  The one on the positive side of the battery.Now, with no warning, the hood will shut down, and I get flashed.  It's the corrosion on the terminals/spring.I tried putting some abrasive paper up in there, and rotating it.  It's inside a tube sorta thing, and you can't really get to it.  Sorta helped, but once corrosion sets in, it's pretty permanent thing to deal with.So now, I gotta give the hood a little smack once in a while to jiggle the batteries so that they make contact properly.  I won't switch hoods.  I love the Jackson.  It's the only one that gives true real colors.  The puddle isn't a green blob, or a blue blob...…...it's the color of molten metal.  Yellows, oranges, blacks...…….it's why they call it the True Sight.And, as expected...……...ya can't get to the spring to replace it.  It's all sealed up in the unit.  Typical new age crap...…...non serviceable.
Reply:I have the Vega view 2.5, I was unaware they made a 2.0, let me tell you the 2.5 is pretty awesome, the 2.0 will be even better, I'll say this, if you ever do a lot of heavy welding, ie: spray arc, you'll find that  shade 12 isn't dark enough  Sent from my moto g(6) plus using Tapatalk http://www.philswelding.com
Reply:Well, I have a small update... I ended up getting the Optrel Crystal 2.0 and have used it a few times for a few minutes here & there and so far I am really happy with it! I bought a brand new Lincoln Powermig 256 and got the helmet for half off. Sadly I've only welded about 4" with the Powermig but have tig welded several steel & stainless steel items and absolutely love the Crystal 2.0 so far with the minimal amount that I've used it.
Reply:So here we have my Crystal 2.0.  In terms of clarity, it is the closest thing to a perfect welding hood there is.The "shade 2" of the Crystal 2.0 is very deceiving. I would call it "shade 0.5", as there is practically nothing there! The e684 is like 10x as dark! The other hood that I have is what I would call a real shade 2 is the HTP Striker CSV (even though it is rated 3, it is significantly ligher than the e684 in the un-darkened state).I was using it yesterday, and I realized I have to retrain my brain! I keep thinking that, even though the hood is down, that I don't even have my hood on and for a split second it freaks me out right before I strike the arc. Its like one of those "oh schit! I almost blinded myself ! Where is my welding helmet!!" kinda reactions! It is stupid-nice! I recommend this helmet over any welder or welding product/consumable ever.You think you're happy. Until you try the Crystal 2.0, you wont realize just how miserable you are! :lol: So I fired up the Invertig 400 to test out the Crystal 2.0 at high-amp TIG.  Right now it will output a max of 350A since it is still on 1-Φ power.  I tested 250A, 300A, 350A.  At 350A, the tip of the tungsten is still discernible, but just barely.  I prefer to see the tip of the tungsten 100%;  I don't like it when it is obscured by the arc light being too bright.  For my eyes, I would say 350A on DC is the absolute max I'd want to use with the 2.0, unless you put on some sunglasses.  It is tolerable for a little bit, but I suspect it might be too bright after about 30 seconds or so.  So IMO, the Crystal 2.0 has a realistic upper limit of 275-300A DC, depending on your eyes.  I haven't tried aluminum yet, but since it is usually brighter, I'm going to guesstimate 250-275A for AC TIG.  I don't think that's big deal for the clarity you are getting.  I'm just gonna order some cheapie polarized sunglasses off ebay to see if I can get away with 400A later when I have 3-Φ; just have to add a little darkness to it.Based on a recommendation, I downloaded an app that uses my phone's light sensor to measure lux, and recorded these values:Optrel Crystal 2.0: 160Optrel e684: 24HTP Striker CSV: 68Not scientific by any means, just some basic data to go by.   But as you can see, it lets more than double the light than my Striker CSV that is rated at 3 in the un-darkened state.  As good as the e684 is, it is a lot darker in the light-state, but it's advantage is that it is rated 1 on angular dependence where the Crystal 2.0 is rated 2, and it darkens up to 13.  I ordered some polarized sunglasses off Ebay to see if I can't get it to play nice with high-amperage.  Just needs to be a smidge darker and it would be perfect for high amp arcs.Last edited by Oscar; 06-07-2020 at 11:56 PM. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Excellent post by Oscar above.I’ve had a Crystal 2.0 for a few months.  The clarity is absolutely astounding.  My other hood’s include an Optrel E684, a Lincoln Viking, and several older hoods.The Crystal 2.0 blows everything else away.Miller Trailblazer Pro 350DMiller Suitcase MIGMiller Spectrum 2050Miller Syncrowave 250DXLincoln 210MP
Reply:retrofitted Miller head gear.  Officially the best piece of welding equipment I own, bar none. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Got some cheap $10 polarized sunglasses.  Only been doing plasma cutting, but they seem to do the trick to darken everything +2 shade levels.   I usually plasma cut at Shade 6, but wearing the sunglasses (first, before I put on my regular prescription eyeglasses, as the other way around doesn't work well for whatever reason), I ended up turning it all the way down to shade 4, and it appears identical to Shade 6-before-the-sunglasses.  Of course you do lose the ultra-light undarkened state because you are wearing the sunglasses, but I have a feeling that 300A+ welding will no longer be an issue.  Also the true-color artifact stays unaffected with sunglasses.  Everything is just as crisp and clear as before, just approx ~2 shades darker. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:I use similar for O/A and plasma but I’m not certain what number shade(s) they are.  Got them from LWS and they weren’t  ten bucks but not much more. I also have the Selstrom Covid Special when it’s impossible to social distance in the shop. :
Reply:need to buy a new helmet and seriously considering the crystal 2.0 but having a hard time justifying the price at 50% of a harbor freight protig 205 for just a helmet .any sales coming up?
Reply:Cheaper by the doz... was checking for Cdn. pricing when I found this one at $989.... but only $791 if you order 2 or more.... https://www.tenaquip.com/product/cry...iABEgIkivD_BwEFound this one on sale for $627 Cdn. .... not sure what pricing you're finding, but if they export to the US your fat dollar might make that a good buy even there....https://canadaweldingsupply.ca/produ...yABEgKbc_D_BwE250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Originally Posted by filetobeefneed to buy a new helmet and seriously considering the crystal 2.0 but having a hard time justifying the price at 50% of a harbor freight protig 205 for just a helmet .any sales coming up?
Reply:Originally Posted by whtbaronCheaper by the doz... was checking for Cdn. pricing when I found this one at $989.... but only $791 if you order 2 or more.... https://www.tenaquip.com/product/cry...iABEgIkivD_BwEFound this one on sale for $627 Cdn. .... not sure what pricing you're finding, but if they export to the US your fat dollar might make that a good buy even there....https://canadaweldingsupply.ca/produ...yABEgKbc_D_BwE
Reply:optrel mentions 4 to 12 darkening and you mention that 12 is a bit light once over 300A welding.they also mention an auto or manual of +/- 2 shades,wouldn't this mean it could potentially go to shade 14 then?
Reply:Originally Posted by filetobeefoptrel mentions 4 to 12 darkening and you mention that 12 is a bit light once over 300A welding.they also mention an auto or manual of +/- 2 shades,wouldn't this mean it could potentially go to shade 14 then?
Reply:Originally Posted by Lis2323I’ve   seen those on Canada Weld.   Not for me.  I’ll pass.
Reply:Will Crystal 2.0 work for TIG welding aluminum, since it only supports up to shade 12?I am planning to learn how to TIG weld, mild steel and aluminum. I have some experience MIG welding automotive stuff, but totally new to TIG. I am wondering if the Crystal 2.0 will be usable for TIG welding aluminum? I am concerned that it only goes up to shade 12, and with TIG being pretty bright I was wondering if it will not be dark enough. I am also considering Optrel e684, Lincoln Viking 3550 and Miller Digital Elite. Cost is not a consideration.
Reply:First time I struck an arc with my crystal 2.0, I went on a road trip two states over to retrieve  my socks.  Expensive trip and expensive helmet.  Hahahaha!  Best lens so far on the planet .Sanrex Sanstick 140s(hotstart&dig set perfectly)Thermal Arc 185( if you've used one u know)Thermal Arc 400 gmsMiller Shopmate 300( best wire arc!)Miller 75dx feederMiller PassportMiller s22p12Everlast 210stl30a
Reply:Originally Posted by juha_teuvonnenWill Crystal 2.0 work for TIG welding aluminum, since it only supports up to shade 12?I am planning to learn how to TIG weld, mild steel and aluminum. I have some experience MIG welding automotive stuff, but totally new to TIG. I am wondering if the Crystal 2.0 will be usable for TIG welding aluminum? I am concerned that it only goes up to shade 12, and with TIG being pretty bright I was wondering if it will not be dark enough. I am also considering Optrel e684, Lincoln Viking 3550 and Miller Digital Elite. Cost is not a consideration.
Reply:Originally Posted by OscarIt will be fine, up to my estimated guess of 275A-ish, maybe 300A, depending on your eyes.This came in today. I got it based off the videos and reviews from Oscar, SCSmith and a few others. The second photo is my phone held up to the lens. It will be a day or two before I use it but I will make sure I post my thoughts as well. Sent from my SM-G930V using TapatalkMillermatic 252 MIGMiller Dynasty 200DX TIGMiller Spectrum 625 PlasmaAltas 12x36 Metal LatheBridgeport Milling Machinewww.psacustomcreations.com
Reply:So how do you like it? I am thinking of getting one but with the PAPR set up.  Would love to know how you like it. Hearing good things and ready to pull the trigger if you give it a thumbs up.  I will do a lot of gas shielded flux core for some heavier fabrication and don't want any of that in my lungs.  Thinking the PAPR will be a good investment for my long-term health.  Have had two cancers when I was in my 20's and not wanting a repeat of that experience.  51 now and every day is a blessing!  just getting into welding in a serious way and love it.
Reply:Surprisingly, really, as the manufacturer claims, the view through the glass mask, as through a normal non-darkened window glass.
Reply:Originally Posted by Chris HSo how do you like it? I am thinking of getting one but with the PAPR set up.  Would love to know how you like it. Hearing good things and ready to pull the trigger if you give it a thumbs up.  I will do a lot of gas shielded flux core for some heavier fabrication and don't want any of that in my lungs.  Thinking the PAPR will be a good investment for my long-term health.  Have had two cancers when I was in my 20's and not wanting a repeat of that experience.  51 now and every day is a blessing!  just getting into welding in a serious way and love it.
Reply:Originally Posted by psacustomcreationsI have used my Crystal 2.0 several times now and like it. It does have a few differences over the Miller Digital Infinity. The Optrel is much clearer in picture but of course has a smaller viewing area. This mostly makes a difference if you keep the hood down while moving items or going from spot to spot to tack or weld. The larger viewing area of the Miller made that easier so I didn't bump into things. The clarity of the Optrel makes it easier to actually see what you are doing.I like the Miller headgear over the Optrel and will most likely swap the headgear and try out the Optrel that way. I have not done that yet so can't report on that.
Reply:Originally Posted by OscarYou might want to wait on retrofitting the Miller headgear onto the Optrel as I and others have done.   Optrel is planning to lend me one of their new headgears to evaluate soon.
Reply:Originally Posted by psacustomcreationsThanks for the heads up Sent from my SM-G930V using Tapatalk
Reply:i got the e684 just months before the 2.0 went on the market . wish i could of got a 2.0 instead as i would be much better in a poorly lighted garage
Reply:Unless you plan on welding at super high amps, sell the e684 and then get the crystal 2.0. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:ya selling it may be a idea. ive only used it for tig and never had smoke or splatter on it. i do quit a bit of welding in a garage and the lighting isnt good. e684 is difficult to see at the 4shade. 2shade would be worlds better. for outside stick welding i just picked up a miller elite. i love the xmode for outside welding. ive had alot of trouble with other helmets outside as the sun can trigger the lens at the worst time
Reply:That's probably a great idea. I hope you manage to sell the mask and buy Crystal 2.0.
GMT+8, 2025-12-18 08:56 , Processed in 0.095901 second(s), 18 queries .
