查看: 19|回复: 1
mig wire 2" reel hole -023 Where can i/?/
发表于 2021-8-31 18:22:21 | 显示全部楼层 |阅读模式
[B]Iam trying to find this .023 copper shielded wire.. for my SP-150 wire welder Lincoln. I can't use a whole roll as sold. But i am told , i won't find a smaller roll than 11 lbs. I need much less than that. Heres where the problem comes in. I had used The .023 wire when chopping my 50 merc ; 11 years ago .I can't find these smaller reels anywhere round me. I have 5/8" Shaft on my lincoln sp150.Only small reels  i find have the 1/2" hole in the reels.ANYBODY HERE....THAT CAN SHARE WHAT to do in this problem????? thanks for anything i can use    bob s i am i lower mich  bob s
Reply:Just ordered some online. If not, but an 11, and respool what you need.
Reply:As far as the spool size, either cut down a big spool and spool, or make an adapter. You can make it out of a bolt, spring, washers, but, small piece of flat bar, and a piece tube that will slip over the spindle.
Reply:Lincoln .025 L-56 in a 2 lb. spool should fit on your 5/8" shaft.Everlast PowerPro 256, Everlast W300 Cooler, Everlast Cart 250Millermatic 211, Spoolgun 100, Miller HD CartJackson W60 Truesight Digital Auto Darkening, Victor 315 Torch sitting on a Harper 830-86 cart
Reply:http://weldingsupply.com/cgi-bin/spi...||1|340
新手上路
Rank: 1
发表于 2021-8-31 18:23:03 | 显示全部楼层
6.10.025" and .023" are comparable.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:1/2 to 5/8 not much difference, is the 2 lb spool plastic? Could you just drill the center out with a 5/8 bit?
Reply:Originally Posted by Weld one1/2 to 5/8 not much difference, is the 2 lb spool plastic? Could you just drill the center out with a 5/8 bit?
Reply:Originally Posted by Grandslam99Lincoln .025 L-56 in a 2 lb. spool should fit on your 5/8" shaft.
Reply:I just went out and checked all the 2 pound spools I have will fit the 5/8" shaft.www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:nope!!
Reply:Originally Posted by mechanic416I just went out and checked all the 2 pound spools I have will fit the 5/8" shaft.
Reply:Well that would sure make a difference. I would take the shaft out and lathe it down to 5/8" so I could use the smaller spools.www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Originally Posted by mechanic416Well that would sure make a difference. I would take the shaft out and lathe it down to 5/8" so I could use the smaller spools.
Reply:You can remove the large spindle and replace it with a new smaller one. complete with spindle adapter for larger spools. For #2 spools you just need a couple of wood spacers.Then you can use the spring assemble to tension the wire. Now you will be set up to run any size roll.
Reply:Originally Posted by mechanic416I would take the shaft out and lathe it down to 5/8" so I could use the smaller spools.
Reply:Think there is one at the shop. have to go look with this in mind.
Reply:I looked at my spool again looks like it could drilled out. Even to 3/4 mabe have to go a little bigger then put a bushing in if you have to. Good luck.
GMT+8, 2025-12-18 09:27 , Processed in 0.062531 second(s), 18 queries .
