Safety with water tanks kills welder
发表于 2021-8-31 15:01:40 | 显示全部楼层 |阅读模式
Here is good reason to follow safety even if just water.This time it kills the welder.https://www.yourcentralvalley.com/ne...on-in-lemoore/Dave
Reply:Damn!Miller Trailblazer Pro 350DMiller Suitcase MIGMiller Spectrum 2050Miller Syncrowave 250DXLincoln 210MP
Reply:Must have been methane in the tank that came out of the well with the water. You could see the flames as the tank went airborn.
Reply:Dam, that's sad. Filled water and it still blew. I wonder what the circumstances were. All tank work we do is still consider a confined space. We always have readings taken before we do anything. It will be interesting to see what they find out. Sent from my iPhone using Tapatalk
Reply:1.5 million gallon tank went 70' into the air there was a lot of gas in that thing you would think with all the water quality testing that public systems are required to have they would have caught that.Do not argue with an idiot. He will drag you down to his level and beat you with experience.
Reply:Originally Posted by BD1Dam, that's sad. Filled water and it still blew. I wonder what the circumstances were. All tank work we do is still consider a confined space. We always have readings taken before we do anything. It will be interesting to see what they find out. Sent from my iPhone using Tapatalk
Reply:Originally Posted by smithdoorThis time it kills the welder.
Reply:Originally Posted by John TThe interesting thing is,He was NOT a welder/weldorHe was a union carpenter.  Hmmm ….
Reply:I agree Even your own water tank and hot water can have expolsey gas.If tank was full  it would be ok or vent with air (after venting i use CO2 to remove most of oxygen too need to calculator the amount of gas need)But City using unlicensed Welder too.A buss box does not make any qualify to do welding.Dave  Originally Posted by BD1Article did say the contractor started welding then the tank blew. Maybe a carpenter that could weld ?? That could the reason to blew. The contractor could have been unqualified.That would explain it. Sent from my iPhone using Tapatalk
Reply:Originally Posted by smithdoorI agree Even your own water tank and hot water can have expolsey gas.If tank was full  it would be ok or vent with air (after venting i use CO2 to remove most of oxygen too need to calculator the amount of gas need)But City using unlicensed Welder too.A buss box does not make any qualify to do welding.Dave
Reply:We are all trained in confined space where I was working. We even had our own equipment and meters. I talked with my owner and suggested to hired a dedicated confined space team. We do the work, but they setup and monitor conditions and tell us when it's safe. He agreed, especially since equipment and monitoring devices need to be certified and recalibrated. This way we know they have up to date devices. The group we use are paramedics and firemen.So they are well trained . You can't Outvavk price on safety. Sent from my iPhone using Tapatalk
Reply:Originally Posted by BD1We are all trained in confined space where I was working. We even had our own equipment and meters. I talked with my owner and suggested to hired a dedicated confined space team. We do the work, but they setup and monitor conditions and tell us when it's safe. He agreed, especially since equipment and monitoring devices need to be certified and recalibrated. This way we know they have up to date devices. The group we use are paramedics and firemen.So they are well trained . You can't Outvavk price on safety. Sent from my iPhone using Tapatalk
Reply:CrazyLast edited by danielplace; 07-01-2021 at 08:40 AM.
Reply:Safety is filling tank full water to top of tank or putting inert gas inside. I know how weld on tanks but I will never welded on tanks.Just one mistake is your last mistake in tank welding. If weld close to a gas tank I fill clear full of water. Just in case of a mistake. Dave  Originally Posted by danielplaceCrazy
Reply:Not welding but a similar experience about 30 years ago when I was building condos. Our lender went broke right as we were doing final inspections on 30 unit condo project. Because the lender was in bankruptcy we were not able to finish the project for almost a year till they went through bankruptcy proceedings and were able to get another lender to take over so that we could actually sell them and transfer ownership. We went back into the units to see what the exact status was. We started powering up units and checking status of appliances.  Someone turned on a dishwasher and after about a minute it exploded. We originally thought that somehow the gas line and a water line got crossed.  The fire department responded and determined that the water heater was partially full of water plus probably some organic material and dirt.  Over the year the water started producing methane from the organic material and when the methane met a spark from the dishwasher motor…BOOM.It blew the door completely off the dishwasher and expanded the tub to the point where we had to cut up the dishwasher to get it out.Fortunately, no one was hurt and no fire ensued.Lifes strange mysteries.
Reply:Thanks for the video, unfortunately very often experience is the enemy of safety.
Reply:I missed the part where it said he was welding inside the tank?  If he was welding on the outside he would not have done a confined space entry.Owner of Fast Leroy's Bar and GrillLiquor up Front, Poker in the Rear
GMT+8, 2025-12-18 11:01 , Processed in 0.103223 second(s), 19 queries .
