Trailer build questions...
发表于 2021-8-31 15:01:39 | 显示全部楼层 |阅读模式
I'm considering building an equipment trailer, and have a chance to pick up a complete set of 7k lb Dexter 8-lug axles for fairly cheap (complete with tires, brakes, springs, etc).  I also have a line on three 24' pieces of 10" C-channel, which look to be roughly 3/8-1/2" thick across the web(?).   Question is, will the C-channel be sufficient for the build, at least to haul 11k lbs?  Based on how I plan to build, I want the deck (with dovetail) to be 24'...which means I will likely be adding a 4' dovetail to the rear.  I know a lot of this depends on how its trussed between the main pieces, but I am mainly concerned with the C-Channel over 20+ feet.  I figure when its done, the trailer will likely weigh 2500-3000 lbs.  It won't be a deckover, and width will be roughly 82".Thoughts?
Reply:For an 11,000 payload, what you describe should be more than sufficient.Miller Trailblazer Pro 350DMiller Suitcase MIGMiller Spectrum 2050Miller Syncrowave 250DXLincoln 210MP
GMT+8, 2025-12-18 10:19 , Processed in 0.096359 second(s), 18 queries .
