查看: 20|回复: 1
Tweco 300 mig gun for Lincoln
发表于 2021-8-31 18:08:16 | 显示全部楼层 |阅读模式
I have two, new in box Tweco 300A Eliminator mig guns, 15' hose, Lincoln back end. I am asking $200.00 each, plus actual shipping."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Bump Anyone?"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Where you at in this awful state?  That compatible with the PowerMIG 300?  I'm not too far from Ohare if you'll do face to face?  S/F....Ken M
Reply:PM sent."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Those backend fittings on Tweco guns swap out if needed.http://victortechnologies.com/tweco/...&categoryID=39
Reply:Back at you with a PM. Thanks Farmall, I believe this is the correct hookup for a PM300, it looks right, I was hoping to have confirmation.  I know the stuff is switchable, I have a No4 Tweco on the PM300 now, but it's more hassle, ya know. S/F...Ken M
Reply:Here's some dimensions I found for the #4 Tweco / Lincoln end:
Reply:I didn't know that farmall, thanks. And Ken yes, please do confirm that this model gun is what you need. If you need more pics I will be glad to get them to you."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:I should add that my example pic doesn't show the hex nut flats that end will have on the Tweco the Stickmeister is selling. If you have a lathe you could very quickly turn the larger 5/6 Tweco end into a 4 if wanted.
Reply:OK, pulled out the #4 on the PM300 and it's the same end you have pictured, farmall.  Now, looking at stickman's gun, the cotter retaining pin will fit, the power lug is correct, the control connection is correct, the only question is about the gas fitting.  Now, I'm guessing I can simply run that clear hose straight to the gas solenoid instead of passing gas through the lug, and presto, I'm in business.  Make sense?  BTW, Merry Christmas and thanks for the help.  S/F....Ken Medit:  Farmall: So you're saying the bloody thing is larger diameter, not just slightly different profile?Last edited by EchoSixMike; 12-25-2013 at 09:35 AM.
Reply:You can run the clear hose straight to the 'noid.Some general Tweco backend conversion/adaptation-fu which may help a variety of folks:The black objects are the female part of Tweco gun adapters. They sell 'em to retrofit a large number of machines (I get them cheap off Ebay) but as far as I've noticed they don't do "Tweco to Tweco" though there is no reason they can't with a suitable thread on the adapter backend which has a SMALLER diameter thread than the standard GUN backends. Black block at 12:00 position is Tweco 5/6 female with a Miller backend partially inserted. (This would adapt large Tweco gun to Miller machine/feeder.)  Top right is a #4 female.Long gun backend (Tweco "Lincoln" style)  at 11:00 position which looks like Sticky's gun with hose barb fits Tweco 5/6 adapter female orifice which is of course larger (backend diameter = ~.744" vs ~.620" on my examples) than the Tweco 4/Lincoln 4 gun backends which are second and third up from the bottom right. There is enough meat to turn it into a Tweco4/Lincoln male. Band clamp in the middle is a Tweco part. You can shorten damaged Tweco MIG guns but no other clamp fits under the shell.   The two gun backends at 8:30 and 9:00 are Tweco for Miller.The Miller Tweco adapter backend on bottom right has plenty of meat (~.680" diameter ) would also be fine to turn into a Tweco 4/Lincoln to adapt Tweco 6 guns for those wanting to run an adapter. I'll eventually do that but not until I get a 5/6 gun that needs it since I don't yet own a lathe.In the case of Stickys gun, I'd check price on the correct backend part number by finding it in the gun manual. You can call Tweco tech support if in doubt. If the price is right then you can just slide out the liner and swap backends. I hold the gun in my left hand with a box wrench on the backend nut then slap that wrench with another and the backends come off with little fuss. They don't need a lot of torque. They don't wear out so save 'em when you have a bad gun. Taking advantage of "less-popular-than-Tweco 4" MIG gun backends to get deals works for me but I don't mind a little fiddling.  I think but haven't confirmed that this Tweco part would fit, but I'd call Tweco with Stickys gun part number first:http://www.bakersgas.com/NAS358-2035-2174.htmlShort version:You could either mod the Lincoln backend on a lathe (a few minutes work since you'd just be shrinking the diameter and making one groove for the retention screw and not have to drill for gas flow since it has the hose barb), buy a #4 backend, or get a #4 female adapter off Ebay with a large Miller "adapter" backend and turn that down to #4 diameter, add hose barb or turn for O-rings then drill for gas flow which would let you use 5/6 Tweco guns untouched and continue to save money if you buy more of same in the future. I always stay "one MIG gun ahead" of the game since they all die eventually.Last edited by farmall; 12-25-2013 at 11:52 AM.
Reply:Or I suppose I could pull the connector off my current #4...  Have to check on that.  Thanks BTW.  S/F....Ken M
Reply:Here are some close up's. I hope they help. If needed I can pull the gun off my LN25 tomorrow, and compare it to this new gun. I can call or text you with the info then. Let me know……."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Hey Stickman, got off the phone with Tweco, got the adapter PN and the LWS has 'em and they're not too bad a hit.  I'll give you a yell, next time I'm south by you, maybe this weekend?  S/F....Ken M
Reply:PM sent before I read this. Sounds good, I will be at my yard all day tomorrow, unless something changes, you know how that goes. Give me a call, thanks."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:What's the adapter part number and price? There are a lot of Tweco and Weldskill guns out there cheap and begging for conversion.
Reply:OK Tweco PN is 2035-2110 which is also listed as 350174H.  They're $37.18 at my LWS, which also does internet salesThis should be the link, but might not work because it's a search:http://weldingsupply.com/cgi-bin/spi...|1|755
新手上路
Rank: 1
发表于 2021-8-31 18:09:06 | 显示全部楼层
37.18S/F....Ken M
Reply:Thanks. Both numbers get multiple vendor hits on Google which is a good thing.Information is power, especially when hunting on Ebay.
Reply:bumpo"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
GMT+8, 2025-12-18 10:45 , Processed in 0.085095 second(s), 18 queries .
