is my welder ac or dc?
发表于 2021-8-31 15:01:30 | 显示全部楼层 |阅读模式
Hi,is my welder ac or dc?will it run 6010 rods?
Reply:Looks like AC just use 6011 it about same rod but you run on both AC or DC.Dave  Originally Posted by O.RHi,is my welder ac or dc?will it run 6010 rods?
Reply:Thank you for the quick answer,Unfortunately 6011 is not available in my country.The funny thing is that 20 minutes from my home there is a factory that make 6011 but only exports overseas.
Reply:The sine wave symbols next to the “180 AMP” leads me to believe your welder is a.c.(as Dave said).What electrodes are available to you?Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:Can you get 7018AC rod?
Reply:Originally Posted by jpump5The sine wave symbols next to the “180 AMP” leads me to believe your welder is a.c.(as Dave said).What electrodes are available to you?
Reply:No, I cant find AC rods at all. Originally Posted by KelvinCan you get 7018AC rod?
Reply:Can you get 7014?IMPEACH BIDEN!NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINEGOD HELP AMERICA!“Freedom is never more than one generation away from extinction.We didn’t pass it to our children in the bloodstream".RONALD REAGAN
Reply:No, not available. Originally Posted by CAVEMANNCan you get 7014?
Reply:Originally Posted by O.RNo, I cant find AC rods at all.
Reply:Some 7018 are dual certified ac/dc - Esab and Bohler over here have dual certs.6013 runs on every stick welder ever made.Looking at that buzzbox i wouldn't want to run anything other than 6013 on it, I have a feeling that it will struggle with anything "stronger"Murphy's Golden Rule: Whoever has the gold, makes the rules.
Reply:Sounds like you've got yourself a nice DOORSTOP!Good luck
Reply:Meh.... depends on how critical the applications are. Lots of things have been stuck together with 6013. I thought my local rod selections were bad, what country are you in?250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Originally Posted by Jack RyanWhat country are you in? It is unusual that there is only one rod available.
Reply:A lot of the commonly available 7018 is actually 7018 even if the box isn't marked as such.What if an AC welder identifies as being a DC welder? Check out my bench vise website:  http://mivise.comMiller Syncrowave 250DXMillermatic 350P with XR AlumaProMiller Regency 200 with 22A feeder and Spoolmatic 3Hobart Champion EliteEverlast PowerTig 210EXT
Reply:If you had some 6010 you could tell if a welder was AC or DC. It is a polarity check rod. The welder in question looks pretty low end which is most certainly AC. I've never seen a single phase DC only machine. All the single phase with DC have AC and DC output.
Reply:Originally Posted by Welder DaveI've never seen a single phase DC only machine. All the single phase with DC have AC and DC output.
Reply:I was thinking of single phase transformers. I've never seen an AC only inverter.
Reply:Originally Posted by G-ManBartA lot of the commonly available 7018 is actually 7018 even if the box isn't marked as such.
Reply:Originally Posted by Welder DaveIf you had some 6010 you could tell if a welder was AC or DC. It is a polarity check rod. .
Reply:I would agree. ( AC input)  transformer (AC output )symbol, 180.6011,6013,7014,7018 whatever you have available. With low OCV, and AC output only you could struggle with 6010 even if you try turning up the amps , but if you only have 6013 you can still do a lot with that. What will you be welding ?cheersAirco 250 ac/dc Heliwelder Square waveMiller Synchrowave 180 sdMiller Econo Twin HFLincoln 210 MPDayton 225 ac/dcVictor torchesSnap-On YA-212Lotos Cut60D
Reply:Originally Posted by MunkulLoads of machines barely run 6010 at all, so pretty pointless to use it to check ac/dc on an unknown low end machine.
Reply:I'm thinking it's an AC machine just from what I see, theres no way to change polarity, 6010 is a DC rod, you're going to need to find 6011, 6013, 7014, or 7018AC, these rods are just about the most popular general purpose rods out there for the hobbyist, I've been welding since the late 1960's, when I started I was a teenager, I'm self taught and mostly a hobbyist, but have welded in my career & had to pass a basic plate test in order to replace the cow catcher and steps on a 125 ton locomotive. That said, for me it's hard to believe that there's nothing available where you live, heck, find a computer with internet access and order the rod, my last 2 orders were done on ebay, I've also ordered on AMAZON and another welding supply place online, I've bought wire & rod at Lowes and Home Depot, I've also bought wire and rod at NAPA, and our local ACE hardware. It's out there, you just have to look. By the way, where are you?IMPEACH BIDEN!NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINEGOD HELP AMERICA!“Freedom is never more than one generation away from extinction.We didn’t pass it to our children in the bloodstream".RONALD REAGAN
Reply:Thank you all for the advice,Ac welding machines are not common for hobbyist here so thats probably why i cant find any ac rods. And also the suppliers wont waste their time for 10 pound order for 1 client.I just orderd a pack from amazon, shipping was little expensive. The price sum up to about double, but it still worth it. And also even the common cheap dc that most hobbyist have cant run 6010 so 6011 is a great solution (if i understood correctly).Originally Posted by Welder DaveI'm thinking mostly of transformer machines where you can actually strike an arc. If no difference changing the cables, it's AC. Ran an SA200 once that somehow the polarity was reversed from what the terminals said. I remember reading how that can happen but forget what causes it.
GMT+8, 2025-12-18 16:28 , Processed in 0.095427 second(s), 18 queries .
