Eastwood Ac/Dc TIG 200
发表于 2021-8-31 15:01:29 | 显示全部楼层 |阅读模式
I want to buy a TIG welder for my son to have to develop his skills for welding. The above welder has AC TIG for aluminum as well as DC for stainless steel. It also can switch to stick and run 6010 rods. Cost is $720. It comes with a foot peddle and TIG torch and goes up to 200 amps. Duty cycle is 60% at 190 amps. I would use it for home projects. Has anyone used Eastwood and does this sound like a reasonable buy?  Sent from my iPhone using Tapatalk
Reply:Primeweld or AHP is a better option.I haven't used the Primeweld but George (mechanic416) on the forum sells them and he doesn't sell crap. The AHP has been around for awhile and is proven. All 3 are made in the same factory but the AHP and Primeweld get the best options and Eastwood gets the left overs. Last I checked the Eastwood was still a mosfet design and the others as far as I know are IGBT (someone correct me if I am wrong)Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:I have an AHP Tig Alpha 201 and Eastwood plasma Cutter.And so far I have had no problems with either. Primeweld seems to have vanished Can't find them on Amazon or Ebay.As far as service and parts. I could not say.Of course I use these at home. But I also had a made in the USA Plasma cutter that took a crap on me after 4 Hrs.of cutting time.So it is a shot in the dark with anything in Todays world.What ever you get,Work the hell out of it for the first Month.Because that is when things happen.
Reply:I found primeweld website. I don’t think primeweld or Eastwood use distributors. Sent from my iPhone using Tapatalk
Reply:Originally Posted by tonylumpsI have an AHP Tig Alpha 201 and Eastwood plasma Cutter.And so far I have had no problems with either. Primeweld seems to have vanished Can't find them on Amazon or Ebay.As far as service and parts. I could not say.Of course I use these at home. But I also had a made in the USA Plasma cutter that took a crap on me after 4 Hrs.of cutting time.So it is a shot in the dark with anything in Todays world.What ever you get,Work the hell out of it for the first Month.Because that is when things happen.
Reply:If stick is what you need watch Craigslist for a good AC/DC welder -- I've seen good units go for $250 or so.
Reply:I have a cheap dc stick welder that does not run 6010. I want one that runs 6010 and also TIG welds aluminum so he can practice on when he takes weld tests. Sent from my iPhone using Tapatalk
Reply:Non of the 3 will run 6010 well at all. They are tig welders that will do stick/arc welding. What you need is a stick/arc welder that does tig, like the Miller syncrowave  200, 250www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:my everlast powerarc 200 STi will run 6010seldom weld anything thicker than 3/8, mostly 1/8 junkCharl
Reply:Originally Posted by Wild TurkeyIf stick is what you need watch Craigslist for a good AC/DC welder -- I've seen good units go for $250 or so.
Reply:Find A Used Precision Tig 275 If He Has To Do 6010 And Tig Aluminum Otherwise The Smaller Machines No Matter What They Say Are Not Going To Be Equal To A Commercial Welder Like A Xmt 304/350 or ivertec v350, just cause they run it doesn't mean they run it well and cause they say they won't run it doesn't mean they can't
Reply:I am trying to be cheap. The welder that would do all I want sounds like it is out my price range. Since it is practice only maybe  6011 in place of 6010 would be adequate. I saw the AHP TIG 200 AC/DC on Amazon for $720 plus $30 shipping and it looked pretty good. I am gonna ponder that one for awhile before my impulse buy. Sent from my iPhone using Tapatalk
Reply:Other entry-level TIG's that run E6010's well are the Esab units, from what I've read, but you won't get AC with an entry level TIG.  AC/DC TIG with 6010 capability you're talking $2000+ easy.Last edited by Oscar; 01-30-2019 at 06:22 PM. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Look for used, the lincoln ideal arc 250 can be had cheep I think they are ac/dc wouldn't be as convenient of a aluminum tig welder as the wiz bang new kid on the block tig welders but a real good stick welder that would be more realistic arc to something you would get on a job
Reply:I started out with the Eastwood TIG 200 AC/DC. I now have the AHP. The only reason I changed is because the AHP had more features such as adjustable frequency and pulser. If I'm not mistaken, the Eastwood has those features now. I loved the Eastwood unit, and put down some great welds with it. I only used TIG though, I don't stick. With both of those units, you'll want to upgrade the pedal (assuming they both still come with that goofy backwards pedal).
Reply:I have this welder, don’t think it will run 6010. I’m happy with it for TIG, would get something more stick-focused if I used stick more.
Reply:You might also take a look at the Everlast PowerTIG 185.  Has AC/DC TIG/stick and is also dual voltage (110 and 220).  Stick up to 150 amps, but 6011, not 6010.  For what you're describing, just for your kid to learn on, I think it would fill the bill.  https://www.everlastgenerators.com/p...iABEgLE1_D_BwE-RuarkLincoln 3200HDHobart Stickmate LX235TWECO Fabricator 211i
Reply:I was purchased Eastwood TIG 200 before one year.. And I found it the best one. You can also try to gain the trust.
Reply:If you are searching for the EastWood TIG 200 from where I purchase. You can visite Proconsumption
Reply:Originally Posted by sheilacorvin298I was purchased Eastwood TIG 200 before one year.. And I found it the best one. You can also try to gain the trust.
GMT+8, 2025-12-18 16:08 , Processed in 0.064895 second(s), 18 queries .
