AWS D1.1 Repair Procedure
发表于 2021-8-31 15:01:25 | 显示全部楼层 |阅读模式
I need to prepare a weld repair procedure for a one time job based on AWS D1.1 2015 but I only have the 2010 version of the code. The 2015 document update summary I have says that 5.26 (which repairs fall under in 2010) was changed to 5.25 and only has a vague description of the change. Does anyone have access to this portion in 2015? Thanks in advance!
GMT+8, 2025-12-18 16:18 , Processed in 0.095004 second(s), 18 queries .
