N.H.R.A. General Rules For Cages/Chassis
发表于 2021-8-31 15:01:19 | 显示全部楼层 |阅读模式
All your questions are answered here about building cages/chassis.http://www.nhra.com/UserFiles/file/G...egulations.pdfIt's in there....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:zapster,Thanks for the Sticky.
Reply:Originally Posted by millratzapster,Thanks for the Sticky.
Reply:Good link.  Interesting to see the differences in required wall thickness in MS vs 4130. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:you da manDave ReberWadsworth Ohio
Reply:That makes for a little light reading. Actually for an old time muscle car guy, such as my self, I don't remember ever reading them. Thanks I saved myself a copy and will read later (too late now).Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:And yet they will grant exceptions to use alternative welding processes provided you supply data that backs up your request.
Reply:Might be nice to add NASA and or SCCA regs as well. In addition to defining the rules, these regs also outline the design and construction principles that should be followed (or at least understood) even if you're not building to a class.Syncrowave 300Maxtron 450, S-52E, 30A
Reply:I also downloaded and saved it.Dave ReberWadsworth Ohio
Reply:Originally Posted by wendellMight be nice to add NASA and or SCCA regs as well. In addition to defining the rules, these regs also outline the design and construction principles that should be followed (or at least understood) even if you're not building to a class.
Reply:If you spend $35.00 at www.sfifoundation.com you can get a book for the chassis you want to build that has the type of tubing,sizes and how and where each tube should go. well worth the money.
Reply:SCCA references to AWS D1.1 for welding will hopefully be changing in the near future once AWS D10.17 is released, since D1.1 has absolutely no business being referenced in an automotive application!
Reply:Downloaded and saved...thank you!!!Also bookmarked the page!!!
Reply:Linky no worky.
Reply:Your kidding right  They are only 5 years old www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
GMT+8, 2025-12-18 14:29 , Processed in 0.095570 second(s), 18 queries .
