[激光焊接机] Welding of iron plate by laser welding machine
管理员
Rank: 9Rank: 9Rank: 9
发表于 2021-6-1 10:06:29 | 显示全部楼层 |阅读模式
视频
视频封面:
Pudian laser welding machine can also weld aluminum, galvanized steel, carbon steel, copper, stainless steel and other metal materials, as well as nuts and studs, rack cabinet chassis, guardrail, sheet metal, hardware, terminal wire, fuse, electrical switch, instrument, battery, coil, metal spare parts, compressor, inductance coil, copper wire joint, silver contact, chip inductance, high temperature wrapping wire Soft connection, etc. Spot welding machine, iron plate fusion, iron plate welding, iron plate welding machine, Dongguan laser welding machine, laser welding machine brand, laser welding machine factory--Metal welding, Just Pudian!
本帖子中包含更多资源
您需要 登录 才可以下载或查看,没有帐号?立即注册
x
GMT+8, 2025-12-18 10:20 , Processed in 0.090609 second(s), 21 queries .
