查看: 13|回复: 0
Can you put a plasma torch on a CNC router table?
发表于 2021-8-31 15:01:15 | 显示全部楼层 |阅读模式
1) My grandson has a CNC router table and wondered if he could hook a plasma torch to it with no modifications other than fastening (removing the router of course). I couldn't answer him so I thought I'd ask here.2) Also, if he can't or doesn't want to go that way, who makes a medium priced 2 x 4 CNC plasma table that works well?I assume the plasma torch is a separate purchase from the table in #2, you pick the one that suits your stock thickness, compressor, billfold.
Reply:Depending on the table it can be done, I have built a few table and most were dual purpose (some with more options).There needs to enough vertical distance so you can mount a cutting grate. Most likely there will be enough as routers have a taller travel in the Z direction.  The attached images show a flat plate on the Z axis that I attached either a router or a plasma torch.  I used a boom for the Plasma cable and the router power and vacuum hose for dust collection. I would suggest putting a water table for plasma cutting as there is a lot of very fine metal dust produced when cutting.  Mine is about 4" deep with a 2" support frame and 1-1/2"X 1/8" slats that the metal rests on.  It will require a small amount of extra wiring for additional circuits for signals. Attached ImagesLast edited by acourtjester; 1 Day Ago at 09:52 PM.DIY CNC Plasma table USB BOB Price THCHypertherm 65Everlast PowerTig 255 EXTMiler 180 Mig13" metal latheMill/ DrillECT, ECT,
Reply:Yes you can put a plasma torch on a CNC router. Several DIY CNC machines do this. It's very common.
Reply:Thank you acourtjester, that's exactly the kind of detail and information that helps us make our decision.He's currently getting his knife blades water jetted, he decided he's a little picky on edge quality so doesn't think plasma edges will work. He's talking about something called fiber laser for in the future. I don't know what that is.
GMT+8, 2025-12-18 09:24 , Processed in 0.088810 second(s), 18 queries .
