查看: 13|回复: 0
Welding casting
发表于 2021-8-31 15:01:14 | 显示全部楼层 |阅读模式
hi there i have this surface grinder whose T slot table chipped and broke in half pretty much the table is removable althought heavy waht set up would you recommend? what welder? at which  settings?   how much heat etc my intention is to keep the broken peice and weld that back to the table ORjust fill it all up ? ? thanks a lot
Reply:Can you post a picture of the table & break, it will help us to come up with the right/best process and approach.IMPEACH BIDEN!NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINEGOD HELP AMERICA!“Freedom is never more than one generation away from extinction.We didn’t pass it to our children in the bloodstream".RONALD REAGAN
GMT+8, 2025-12-18 08:56 , Processed in 0.084643 second(s), 18 queries .
