Torch Cart
发表于 2022-5-19 11:02:56 | 显示全部楼层 |阅读模式
I want to build a cart to hold the tanks one in front of the other instead  of side by side. I want the acetylene tank to go in first it will be the common size then i have some L oxy tanks i will use. I have a ideal how i will build it but would like to see some like what i want but i havent ran across very many.This set will stay in the shop so i dont need very big wheels.
Sent from my iPad using Tapatalk
Originally Posted by Old Doug
Did you build the wheels? I got a new ideal from looking at yours. I have a cart that has my other torch bottles oxy/propane it dosent have very big tires. I may use the cart i have now for my oxy/ acetylene torch then build the other with bigger wheels to hold my oxy /propane torch that goes out side alot.
GMT+8, 2025-12-18 16:42 , Processed in 0.107133 second(s), 18 queries .
