查看: 13|回复: 0
Miller big 50. AC or DC?
发表于 2021-10-11 15:51:28 | 显示全部楼层 |阅读模式
Miller big 50. Is the power originating from the generator AC or DC? And what would the voltage be?
Reply:I've read the entire manual and it does not mention anything about what type current originates from the generator. It talks about AC and using it as a backup generator and even how to hook it up on one that is factory prepared for it, mine isn't that's why I need to know where to connect  my 240 breaker and transfer switch. If it's original current is  AC inverted to DC for welding I could figure the rest out. If it's original current is DC inverted to AC I would need to know where that takes place. Thanks for your interest.
Reply:Those machines use a 3 phase alternator rectified to DC for weld output. Couldn't tell you what the 3phase voltage is though.
Reply:Check it with a multimeter. I'm pretty sure they use an alternator to generate AC though.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power
) Hobart MIG
GMT+8, 2025-12-19 13:15 , Processed in 0.091130 second(s), 18 queries .
