Long beads
发表于 2021-9-1 00:40:05 | 显示全部楼层 |阅读模式
Hey folks!   Had a field call after lunch today. Seems that an outfit out of San Fran. that is erecting a building here in town made a little goof. They had welded the wrong plates on a  beam, needing a saddle instead of a knife-plate in two locations. The new plates are 3/8 x 10" x 32". Specs called for a 5/16 fillet continous on one side, stiched on the other. Overhead. 12' up. I remembered to kinda time two of the passes and they ran roughly 4 min. ea. Yes, my arm got tired.  But it was a good tired. Attached Images
Reply:Dear God Tek you cant beleive how happy that makes me to see someone else that can weld longer than 2 mins    SEE Arcdog(brian)  Tek here can weld it for longer than 2 mins and keep it nice and purdy IF it Catches...Let it Burn
Reply:Hey Tex. Glad I could put a smile on that mug o'yourn!  Hope your gettin' better bud. I was recently out of work for three months due to an injury(gr. 3 sep. shoulder/surgery) so I kinda know where your at. Stay loose bud.
Reply:Long beads make stronger welders , and happier women heh!
Reply:Egads I don't think I could hold an empty hand up for 4 minutes.. Excellent work there by the looks. BTW, did you do the stitch side first ?
Reply:Sandy-I kinda cheated. I was on a scissor lift and had the perfect height to be able to rest my elbow some what on my hip or belly as I went along. Also I was dragging my right hand along the plate and using it for support(left handed Weldors rule!) Yer right, stich first after good tacks and kicker brace.
Reply:a weld longer than 2 min i dont bleve it  j/kChuckASME Pressure Vessel welder
Reply:LMAO  IM hoping arc dog sees this IF it Catches...Let it Burn
Reply:we did a 24" reseaver at work yesterday and a single pass is 3min or there a bouts i did not get to do the weldinng  just fitupChuckASME Pressure Vessel welder
Reply:oh bummer.....sorry to hear that chuck....I know you lke to weld   I kinda enjoy doing the fit up though.  I just hate it when some sloppy @ss trigger puller comes alongs and makes a sloppy weld after I made evertying puurfectIF it Catches...Let it Burn
Reply:yea he dont know how to do pipe to many stop and starts for meChuckASME Pressure Vessel welder
Reply:wow.............im so glad to see that Chris is now the welding nazi on this board !d-
Reply:Sorry brian but youre the racist   cant deny it we know how you feel about hispanics IF it Catches...Let it Burn
Reply:Thats IT, NO RODS/SOUP FOR YOU!!!We need to protect Freedom of Speech, otherwise, how would we know who the A-holes (like me) are.
Reply:I dont care none about the rods....but Ill sure miss the soup IF it Catches...Let it Burn
GMT+8, 2025-12-21 13:15 , Processed in 0.264507 second(s), 18 queries .
