Well this was slightly diffrent for a change..This came from the local Cottman Transmission shop.."Newer" Dodge minivan Tranny case..Seems the pin that holds the gears in the chuck got loose and started rubbing its way out...Upon inspection I had determined that what was left of the casting was only about .015 thick..So instead of making a big molten yuck out of it I decided the best remedy would be to loose the rest and make a piece to fit..So it was die grinder and wax time..Off to the stock rack for a piece of 3/4"X3"x1/8" aluminum..Cut..sanded the corners and rubber hammer bent in a vice..So now its tack it in time..Note the black soot from the casting..Just wire brush it off and continue..(Yes i know the top right tack is cracked..so do it over)And we continue on the next post.....zap!Last edited by zapster; 02-02-2007 at 05:04 PM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Ok..Here is the first pass..It came out well so i did'nt need to go over it..But I had to grind it down alittle so there was clearance..No off to the other side..Weld and call it a day..80 Amps..1/16 5356 (casting)A.C.Mix gas..38%Red end..Time of repair..1hr..I get all the fun jobs.....zap! Attached ImagesI am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Nice work there zapman. Tigman extrodinare strikes again.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:Originally Posted by DoolittleNice work there zapman. Tigman extrodinare strikes again.
Reply:Hey, when you said you mixed a gas, what was it? helium argon? I saw smith sells those gas mixer regulator doodads. Works good?Holy big bucks zapman.. Those things are like 2 grand!! Had to edit my post because I was looking at what it took to mix on your own..Last edited by Doolittle; 02-02-2007 at 06:32 PM.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:That is an extremely common failure in those Caravan transmissions. I'm supprised that a newer one would have failed because that would indicate the problem still hasn't been fixed.
Reply:good job as allways zap ChuckASME Pressure Vessel welder
Reply:you are using red tungsten with and inverter or with a transformer machine?
Reply:Originally Posted by mstillsyou are using red tungsten with and inverter or with a transformer machine?
Reply:Originally Posted by zapsterWell the one I got came from e bay for cheap..I had to modify it but in the end..I'm happy I go with 38% argon the rest helium..Ask lorenzo..He never had a gas mix like that..So I had him use my machine with straight argon..Then the mix..I proved that it is diffrent to him anyway....And he agreed..If you ever get a chance to try one do it!...zap!
Reply:Originally Posted by zapsterAsk lorenzo..He never had a gas mix like that..So I had him use my machine with straight argon..Then the mix..I proved that it is diffrent to him anyway....And he agreed..If you ever get a chance to try one do it!...zap! |
