Critique my TIG weld
发表于 2021-9-1 00:34:07 | 显示全部楼层 |阅读模式
Please critique my weld, what can I do better? Thanks for any help.
Reply:Not bad, it looks like your not using enough filler (or none at all...are you fusing?) and pushing your puddle a little too far...a tad too thin IMO. Otherwise, you have the technique down good! John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Judging by the white crust..Its Aluminum...Pics are so-so.. But it looks even..But we have no info on material..Filler..Base settings for said Critique....After that..We'll let you have it.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I would like to see the back side for the penetration if possible...Strive For Perfection
Reply:Only recommendation I'd be able to give is to not weld on the carpet.ThermalArc 185MillerMatic 180 w/ AutosetVictor Cutskill Oxy/AcetyleneThermal Dynamics Cutmaster 38and spite!
Reply:Yes, Im just fusing it. Im trying to get the technique right before I start adding filler. As for the info, its 1/8 aluminum, as for what kind, I dont know. 3/32 red tungsten with a 130 max. I would get a picture of the backside, but photobucket isnt working right now, maybe later.
Reply:Try www.imageshack.us for photo hosting.No sign up, email or any of that stuff unless you just want to do it.
GMT+8, 2025-12-21 19:34 , Processed in 0.125863 second(s), 18 queries .
