Well I was board this morning sooooo....What better to do than "play some games" while the lathe turns...Tig process..Vertical up prep..Vertical up weld..Vertical down weld..Vert sideways steel prep..Vertical sideways steel weld..Now on to the Aluminum portion of this program..(Next post)...zap!Last edited by zapster; 03-10-2007 at 11:29 AM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Same thing but diffrent..Aluminum this time..Prep..Vertical up weld..Vertical down weld..Vertical sideways prep..Vertical sideways weld aluminum..Ok...Now the welder was set on 200 amps...All I did was change over from steel set-up to aluminum set-up..Amps stayed the same...I like "playing games" while there is nothing better to do.. Carry on!!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:hmmm, u should make me some badass fabbed valvecovers...lol
Reply:Originally Posted by LSX89RShmmm, u should make me some badass fabbed valvecovers...lol
Reply:Originally Posted by zapsterFor what?...zap!
Reply:Originally Posted by Patriot PerformanceAn LS1 of course!Am I right LSX89RS?
Reply:Just an FYI, the correct (AWS) term for what you call "vertical sideways" is actually "horizontal" or simply "2G."Visit Tensaiteki.com
Reply:Nice work zap.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:Originally Posted by TensaitekiJust an FYI, the correct (AWS) term for what you call "vertical sideways" is actually "horizontal" or simply "2G."
Reply:SOOOOO how long to weld that nice??My Babies: HF Drill pressHF Pipe Bender3 4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:So do you feel you visually noticed any difference in any of the travel directions that indicated a better penetration factor between any of the coupons? Did you see any notable difference in the amount of wire you used running the vert up vs. the down? Just curious....._________________Chris
Reply:Up and sideways..No big deal..Downhill however was a challenge to say the least..MORE filler downward..Seems like you have very little control..But the aluminum was much easier to do.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Thanks for posting this up. Gave me a better idea on TIG handiwork. Ive been having a heck of a time welding down, but much easier going up. Good to "read your bead".ThermalArc 185MillerMatic 180 w/ AutosetVictor Cutskill Oxy/AcetyleneThermal Dynamics Cutmaster 38and spite!
Reply:Originally Posted by DirtyLittleSecretThanks for posting this up. Gave me a better idea on TIG handiwork. Ive been having a heck of a time welding down, but much easier going up. Good to "read your bead".
Reply:Haha...whats so wrong with freehand? Thats all Ive been doing! I guess Id learn faster if I figure out the "walking the cup" huh?ThermalArc 185MillerMatic 180 w/ AutosetVictor Cutskill Oxy/AcetyleneThermal Dynamics Cutmaster 38and spite!
Reply:Ok, what Ive learned (from class so far) is that downhill just plain sucks. With mig, its a bear to get good penetration because of gravity pushing the puddle along. What I was told, is that its mostly used on thin stuff like sheet metal, and 3/16 is the max you want to go when doing it. I guess it has its place, and is something of a challenge for me (I can weld it, but getting full penetration is the trick). With up and mig, you fight a convex narrow bead that is tricky to control. Too hot, wire not right at the edge of the puddle sags out, wire shoots through etc etc...I did a gas weld in the up once. I did it just to see if it was possible. It was ugly, but was sound. Didnt look anything like zaps example with the tig.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:Originally Posted by zapsterThank you.. (I never got into the tech terms)
Reply:I was just going to comment on that!! Sideways=HorizontalYou got to be yourself!
Reply:Zap when do the classes start and how do I join???
Reply:weather you weld vert.up or down flat or horizontal if the joint are all the sameit will take the same amount of filler with vert down you just put down less per pass and run more passes as for penetration it's less than vert up but with the right joint prep. and good fusion the weld will be just as goodChuckASME Pressure Vessel welder
Reply:Originally Posted by infroZap when do the classes start and how do I join???
Reply:Yeah its called horizontal. Vert up does leave better penetration. Say if you want a challenge..... try achieving spray arc in GMAW doing vert up on 3/8". weld it like you own it
Reply:Originally Posted by zapsterWhatever that is.. I like things with carburators.. ...zap!
Reply:Hey Zap can you take a pic of the torch position you used while welding them? Just curious =) Thanks manMy Babies: HF Drill pressHF Pipe Bender3 4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Spray? Didnt think you were supposed to do that on vertical. Hmm, sounds messy.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.Man, TIG runs the same whatever direction you run. |
