Ideas for accessories for receiver hitches?
发表于 2021-9-1 00:33:08 | 显示全部楼层 |阅读模式
Looking for some thing I could build on weekend for my hitchThanks
Reply:Vise mountOther tool mount, like for a roller or bendersmall work table, maybe even fold upBike rackMountable winchTrailer (had to throw that in  )
Reply:I was thinking the vise Mount and table but wanted some other more out there ideas and i definitely plan on building a trailer when there is less snow!!!!!!!!!!!!!!!!!
Reply:Also thanks for the quick responce i am new here so this makes me want to post more
Reply:I built a Bumper Dumper once!Thats a toilet seat mounted into a receiver hitch.Patriot Performance AutoLincoln Power Mig 255CLincoln AC-225 StickVictor Journeyman O/AQuincy QT-5 Compressor
Reply:I have built an engine hoist for changing engines in the pits.. No I don't have any pics...This was years ago.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:thats it an engine hoist                 thanks
Reply:I built a table w/ beach umbrella while sitting on tailgate while surf fishing, also built a game style crank for lifting generators or welders onto truck, all out of 2" sq. tubing
Reply:I saw a receiver mounted (foot) step at Northern Tool that looked interesting.
Reply:The most useful item I have built for a receiver hitch is a tow point.  Two inch tubing with a 3/4" plate for the shackle.  If you have a truck, sooner or later  someone around you will be stuck.
Reply:I built a quasi engine hoist that I used to pull fence posts out of the ground.  Just back the truck up to fence post hook on pump it up and drive it out of the hole.  Beat the hell out using a pick and shovel.Michael
Reply:An anvil could be handy at times.Something else I've seen guys do is build a base for their tube benders to use a receiver.  Like for building roll-cages and such if you don't have a way to mount it to the floor, or just want it portable.I thought about the crane idea, adapting a harbor freight one for use in a receiver.  I think it would work best if it were put off to a side instead of the middle though.
Reply:Thisor thisMy Photos on Flickr
Reply:How about something really practical  , like a mounting system for a BBQ, Smoker, or even a Wok?  Gives new meaning to the term "Tailgating".Hobart 140 Handler w/ gasHyperTherm Powermax 380 Plasmaoxy/acetylene
Reply:Skeet thrower mount. Came up with this idea today. Have it stick out far enough so you can sit on the tailgate and have the thrower at waist level in front of you. This will work for those designed to be mounted on a tire. Brace/gusset as needed to make it sturdy.
Reply:A friend did a swing away gas grille for tailgating.  I will see if I can find some pictures.
Reply:Anybody know of a set of plans for a bike rack?
Reply:Originally Posted by jknight8907Skeet thrower mount. Came up with this idea today. Have it stick out far enough so you can sit on the tailgate and have the thrower at waist level in front of you. This will work for those designed to be mounted on a tire. Brace/gusset as needed to make it sturdy.
Reply:TEXAS LONGHORN HITCH COVER   yee haa
Reply:Originally Posted by paintmanTEXAS LONGHORN HITCH COVER   yee haa
Reply:I am going to make a crane this month that mounts into my receiver. Plan to have two outriggers on it, trailer jacks. I want something that will reach rather high and able to lift alot.Patriot Performance AutoLincoln Power Mig 255CLincoln AC-225 StickVictor Journeyman O/AQuincy QT-5 Compressor
Reply:Originally Posted by Patriot PerformanceI am going to make a crane this month that mounts into my receiver. Plan to have two outriggers on it, trailer jacks. I want something that will reach rather high and able to lift alot.
Reply:Originally Posted by jknight8907Hmm. You know receivers aren't really designed for torsional and side loads, right?
Reply:The one I planed to build has two trailer jacks to take the load off the hitch.I know that my hitch can hold a 600 pound tongue load.
Reply:Originally Posted by blue4lifeThe one I planed to build has two trailer jacks to take the load off the hitch.I know that my hitch can hold a 600 pound tongue load.I dont think you'd have any problems.  Used to work for a horseshoer years back.  Used the hitch to mount all sorts of things to beat on.  Even had a medium anvil to wail on.ThermalArc 185MillerMatic 180 w/ AutosetVictor Cutskill Oxy/AcetyleneThermal Dynamics Cutmaster 38and spite!
Reply:Hey!  we need to get some pictures posted of all these great ideas.  Id like to see what they look like!  Now is not the time to be shy.
GMT+8, 2025-12-21 20:29 , Processed in 0.156743 second(s), 18 queries .
