Small Engine Repair
发表于 2021-9-1 00:33:06 | 显示全部楼层 |阅读模式
This is a Tecumseh engine that ober-revved and threw the rod out the side of the block. I tigged in a new piece. Attached Images
Reply:Lot of fun was'nt it?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:You got that hole in a "lucky" place (if there is such a thing as good luck when throwing a rod?).  Nice work.  I figure the block is aluminum?
Reply:Yeah its cast Aluminum..I did alot of this..http://www.weldingweb.com/vbb/showthread...ighlight=Blown...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterYeah its cast Aluminum..I did alot of this..http://www.weldingweb.com/vbb/showthread...ighlight=Blown...zap!
Reply:Originally Posted by phila.renewalYouch, now that was an unlucky break (but still could have been worse, huh?).
GMT+8, 2025-12-21 20:31 , Processed in 0.070688 second(s), 18 queries .
