查看: 13|回复: 0
customer complains of a hissing noise
发表于 2021-9-1 00:30:32 | 显示全部楼层 |阅读模式
with out hitting anything how would somthing like this happenLast edited by MicroZone; 05-17-2007 at 06:52 PM.63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:Not sure what we're looking at but maybe it was dropped ?John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:F450 exhaust (thanks for fixin pics micro) it cracked down the middle of the weld.63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:WTF???I've never seen anything like it..Its allmost too good.. ..zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:how old is it?
Reply:Is it the turbo pipe or exhaust?..zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:It looks like that is right off the catalytic converter. The entire exhaust system is very heavy. It's possible he lost a hanger and it's been hanging or vibrating for some time.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:exhaust from down pipe thats where it goes into the catalytic converter so to speek truck has 40,000 miles on it.  no dings or dents indicating that it had been hit.63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:all hangers in place and vo vibration while running63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:No flex joint pipes...common problem on turbo systems without them. The constant hot / cold will crack, break and seperate the pipes.Besides...it's a FORD. You expect it not to break?  ...just messin'.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by usmcgremlin... truck has 40,000 miles on it.  ....
Reply:for some reason due to weight restrictions this is not covered under warranty....if it was a 250 350 or 550 it would be covered.  I dont know who makes these stupid rules  I say it should be covered.   895.00  plus 2 hrs labor this company is looking at around 1100.00 for me to change it63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:hot exhaust and water.... stream crossing or big puddle.
Reply:Nah, it's stainless.It does have to do with thermal stresses and fatigue.  Has anybody here worked on a Jeep Cherokee with the 6 cylinder and seen one that didn't have a crack on the header on the least 2 cyinders where they all converge?
Reply:Originally Posted by usmcgremlinfor some reason due to weight restrictions this is not covered under warranty....if it was a 250 350 or 550 it would be covered. ...
Reply:Right GMC - happens on alot of factory cars with thermal stresses. As of lately, GM uses alot of cast on their exhaust manifolds.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by usmcgremlinfor some reason due to weight restrictions this is not covered under warranty....if it was a 250 350 or 550 it would be covered.  I dont know who makes these stupid rules  I say it should be covered.   895.00  plus 2 hrs labor this company is looking at around 1100.00 for me to change it
Reply:it was checked with the warranty clerk in the emmissions guide63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:Sounds like a really good excuse to run with an open exhaust!!!
Reply:lol ....63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:gremlin, where is the crack. my company 550 i had and my personal 450 both cracked around the weld to the convertor. it was form vibration i say. they were both long beds and had exhaust that went on for days. i added 2 extra hangers and rewelded. no more exhaust leak. also, are they wanting to replace the whole thing or just repair what is broke?"Retreat hell, were just fighting in the other direction"Miller Trailblazer 302, Extreme 12 VS, Dimension 400, Spectrum 375, HF 251D-1, Milermatic 251 w/ spoolgun  Hypertherm 1000Lincoln sp 1702000 F-450 to haul it
Reply:Piece of cake fix if you can mirror weld Is that stainless to carbon? Stainless to stainless?Either way, clean it and weld it. Easy money.
Reply:Would like to know why it cracked 'cause . . . won't it just crack again past where you weld it?  Looks like the original weld did not crack.
Reply:BACKUPROLLER:   front of converter ....I am changing the whole section plus the converter63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:Good point, and then they'll expect warranty coverage from YOU whether it was the welds or not!EDIT: if changing out the whole dealio, maybe you'll avoid whatever the factory didn't...Originally Posted by MicroZoneIt looks like that is right off the catalytic converter. The entire exhaust system is very heavy. It's possible he lost a hanger and it's been hanging or vibrating for some time.
Reply:I have welded a few cats like that most on ferign cars.  One I did was too late and the cat had already bit the dust due to too much fresh air getting into it.  I had to replace it anyhow.  These were bolted directly to the manifold.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Originally Posted by zapsterIf thats the case then its not a diesel..
Reply:My '99 Turbo 7.3..Nope..I dont think todays do either.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I'll bet they do. I'm surprised yours doesn't, actually.  My 96 Dodge does.
Reply:Originally Posted by MAC702Is that from the dealer or from Ford?  I'll bet if he calls the BBB, it'll be covered.
Reply:thats y i checked with the warranty clerk63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:Originally Posted by MicroZoneRight GMC - happens on alot of factory cars with thermal stresses. As of lately, GM uses alot of cast on their exhaust manifolds.
Reply:What year F450 is that?  Doesn't Ford have a recall on their 07s due to a malfunction that allows EGTs to get crazy high?
Reply:its an 0463' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:Easy fix,, LOOSE THE KITTY!!! LOL  I know, tampering with any emissions device is illegal according to the USDOT....  But really it must have lost a hanger as mentioned above, and the STOCK exhaust is heavy on these, mine is a 4" turbo back STRAIGHT PIPED exhaust, the only one for a Turbo diesel...lol(My 03 did not have a Cat from the factory, FORD was very funny in how they determined what had one and what didnt, transmission was one factor, I never really figured it out. (All 6.o liters have one though)
Reply:i work for ford. no it did not loose a hanger that section was replaced and truck has not been back for any other type of repairs63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:I would say the cause is vibration.  My car (vette) has a mandrel 3" dual exhaust system and the mufflers have a square shaped outlet.  The outlet are FOREVER cracking and then making an aweful vibrating noise that really just erks the crap out of me.  I have them replaced - they again break.  Put more thickness to them, they still break....Just the other night started the first step in replacing them......but its all from the resonance that the exhaust produces - must just vibrate the stainless like crazy...even put a support in the center as the last ditch effort...one side held, the other cracked!  The car is pretty loud and does produce a great deal of vibration if your near the rear of the car.....you can feel it in your chest...sets off car alarms all over town as I drive around.  Best Times with 434 Naturally Aspirated Vette60 - 1.261/8 -  6.37@ 107.25 MPH 1/4 - 10.08 & 134.9MPH1/4 - 9.60@144MPH
Reply:Originally Posted by ski_dwn_it......sets off car alarms all over town as I drive around.
Reply:Originally Posted by usmcgremlinF450 exhaust (thanks for fixin pics micro) it cracked down the middle of the weld.
Reply:there is no such thing as a viberation free exhaust. its a ford they fall apart. looks like it happened over time not all at once. should of bought a cummins he wouldnt have problems like that.
Reply:Originally Posted by MAC702Both my trucks do that, but esp. the unmuffled Ford 460.Never gets old, does it?
Reply:the dodges down here have worse problems than the exhaust....lol i like cummins dont get me wrong but if you (rebeltait) what to talk about falling apart what about the chevys interior. lol63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
GMT+8, 2025-12-21 23:52 , Processed in 0.070187 second(s), 18 queries .
