putting the new mill to work
发表于 2021-9-1 00:21:53 | 显示全部楼层 |阅读模式
i been meaning to make aright angle plate for some time to use at workand now i have the stockmilling it ChuckASME Pressure Vessel welder
Reply:making the web a right anglefitting it for tack upwelding doneChuckASME Pressure Vessel welder
Reply:Looks like fun, that should last a while! Any problems keeing it square while welding?
Reply:Nice work.What kind of mill is that?
Reply:Cool chopper! "Just dickin' 'round in the shed"A good guess is better than a bad measurement
Reply:Originally Posted by puengueNice work.What kind of mill is that?
Reply:MrRodeoCC:Any problems keeing it square while welding? no,it came out useable cloese ,but i sitll squared it up after it cooledpuengue:Nice work.What kind of mill is that? thank you its a jetBrett:"Just dickin' 'round in the shed" yes ChuckASME Pressure Vessel welder
Reply:Not bad! I'm a little surprised to see you mill first and then weld. I would have thought that you would have welded first then machined. Not quite sure how to machine those large surfaces square with that machine once you welded it up though...
GMT+8, 2025-12-22 11:14 , Processed in 0.109193 second(s), 19 queries .
