查看: 13|回复: 0
New work bench in process
发表于 2021-9-1 00:19:06 | 显示全部楼层 |阅读模式
Just had to add a little stain and varnish. Tomorrow going to run an edge of diamond plate to conceal the edge of the 5/8" plywood, and mount it to the wall. Attached ImagesGood judgement comes from experience.Experience comes from bad judgement.
Reply:nice looking bench...AWS CWI/CWEASNT NDT Level 2 PT/MTAWS Certified Welder(aerospace)
Reply:good job...I like the corners.....Run whatcha brung...otherwise watch...
Reply:Nice lookin' bench...good job.If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:Now you just need to put all the tools and stuff on the open surface you just created.  Nature abhors a vacuum...I mean a clean worktable...nature abhors a clean worktable.Good job.Smithboy...if it ain't broke, you ain't tryin'.
Reply:Ok, is that better. Attached ImagesGood judgement comes from experience.Experience comes from bad judgement.
Reply:Nice bench! Nice welds, too!Sprinkle some chips and swarf on it and it would be Perfect-o! I may need find a way to bolt one to the wall here.  Mine twirls about the shop almost anytime I yank on something clamped in the vise. Last week I mounted a bar bender on the other corner that speeds up the twirls!! Member, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
GMT+8, 2025-12-22 15:57 , Processed in 0.068535 second(s), 19 queries .
