bsr
发表于 2021-9-1 00:18:15 | 显示全部楼层 |阅读模式
im going to make a bsr (bar stool racer) i was was wondering what type of metal should i use and what type of welding rods for my arc welder.
Reply:any one
Reply:Arc welder, you´ll need 7018 if it is DC and 7014 if you use AC or the 7018 AC version. You should use 1" square tubing with a 1/8" thickness or the equivalent in tube. Check out barflyracers.com forum lots of good info and projects.My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:I agree... BarFlyRacers.com..I would also suggest a set of plans to help you out.  They will save you money in the long run and lots of headaches.Build a Barstool Racer at BarFlyRacers.com!
Reply:Agreed.
Reply:6013 is all you want and need for this sort of thing.
GMT+8, 2025-12-22 17:43 , Processed in 0.365132 second(s), 18 queries .
