Mig Gun Holder for welding table.
发表于 2021-9-1 00:17:38 | 显示全部楼层 |阅读模式
This is a mig gun holder I made for my welding table. It slips on anywhere around my table. I am going to drill and tap the bottle so I can put a thumbscrew in the bottom to tighen it anywhere I need to. Attached Images
Reply:I like it, thanks for posting the idea.JimCut an MGB and widened 11" C4 Corvette suspension and LT1 Chevrolet power & 6 spd. Pictures here:Part 1http://forum.britishv8.org/read.php?13,7581Part 2http://forum.britishv8.org/read.php?13,22422
Reply:I think I need one of those. Thanks for the ideareber
Reply:Nice work except for the paint on the tailgate.pro-level dumpster diver                                     Hobart 125EZ
Reply:You should turn it over to have the gun under the table and out of the way.
Reply:Looks pretty handy man! I bet you could sell those ebay!Live each day to the fullest because tomorrow may never come.
Reply:This is the one that comes to mind . . . Steve Attached ImagesMillermatic® 251
Reply:Is that thing strong enough to hold a mig gun?Seriously though... If you were running production, what would you choose for materials?How much of that weld would you really need?It's a great idea! I built 6 of them and welded them under the table, but a couple "moveable" ones would haved served me better.The best things in life all come on a stick!
Reply:Great idea.  I'm going to build mine now.Lincoln AC225 & MigPak 140, Lincoln Magnum SpoolGun, Miller Spectrum 375-X Plasma, Syncrowave 200 TIG, Millermatic 252 MIG, Miller Digital Elite, General 7x12" horiz/vert bandsaw, 3' box/pan brake, 20 ton press, milling machine, 12x28 lathe, etc.
Reply:I put mine on a magnet from a magnetic ground. That way I could move it quickly. Those magnets are very strong...strong enough a 400a gun won't pull it over at all.
Reply:Originally Posted by DDA52I put mine on a magnet from a magnetic ground. That way I could move it quickly. Those magnets are very strong...strong enough a 400a gun won't pull it over at all.
Reply:nice... good idea. theres a holder for a gun on my welder but it always bends up the wire when you put it in. yours looks practicalM Fed
Reply:A magnet on the bottom would be nice so you could clip it on the side or put it anywhere on the table and it would work.
Reply:Originally Posted by eyeshurtnice... good idea. theres a holder for a gun on my welder but it always bends up the wire when you put it in. yours looks practical
Reply:I'm kinda a newbie here even though I've been a member of this website for awhile. this is my first post. The MIG gun holder is a good idea. I saw this thread last Sunday and on Monday I built a portable one with some scrap material at work. It became a hit at work. Most of our welders are positioned on overhead swing-arms and the "holder" on these swing-arms are just hooks which really don't secure the guns. So now the rage with "government jobs" is building these holders. Some have built thiers to position the gun under the table and others have built ones above the work table. Gone are the hooks and in with the holders! I'll post some pics of mine soon.
Reply:Here is my MIG Gun Holder. I made it from mild steel and the holder is slanted at a 70 degree angle for easier insertion and removal of the gun.  I did not weld a washer in the end of it as the tube is longer than the nozzle and bending the .035 wire would not be a problem for me. It took about an hour to gather the materials from the scrap bin and build. Since our shop also uses Powder Coat paints, I had it painted to match most of my custom-made jigs and fixtures. The extended anchor bolts come in handy as an additional grounding connection for my weld table should it be needed when stud-welding bolts onto the parts I'm building that are too small to use a ground clamp directly. Thanks 737Mechanic for the idea! Attached Images
Reply:Good job that looks good, I like the bolts. Mine has been very handy. I move it all the time to where I am working and has been a big time saver.
Reply:I've been thinking about making a holder for mine, but I couldn't think of a design. Thanks for the ideas, they all look great.Lincoln AC/DC 225/125 Stick Linde HDA-300 MillerMatic DVI MIG Miller Dynasty 200DX Hypertherm Powermax 1000
Reply:Heres my permanent torch holder. Made it before seeing the bolt on type. Wish I would have done one of those.. Attached Images
Reply:Nothing is permanent...
Reply:Originally Posted by seamusNothing is permanent...
GMT+8, 2025-12-22 18:01 , Processed in 0.073457 second(s), 18 queries .
