Mig welding brass
发表于 2021-9-1 00:16:28 | 显示全部楼层 |阅读模式
I'm looking to overlay a cylindrical piece of brass using the mig process with a semi-automated rotary welding machine. It's a bearing wear area that I need to fill and machine back out. Does anyone know what there is for mig wire out there (that's as close to the base metal as possible) that I could use to do this??
Reply:mig welding brass?hmmm i've tigged aluminum brass before but migging brass is a new one on me...i'd have to say no......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:depending on what typ of brass yes there is and yes you can mig brass use 100% argonChuckASME Pressure Vessel welder
Reply:You sure it's not oil impregnated bronze?  You can't weld that.
GMT+8, 2025-12-22 21:01 , Processed in 0.155090 second(s), 18 queries .
