One more for now
发表于 2021-9-1 00:16:02 | 显示全部楼层 |阅读模式
This is the one my daughter took off with. No brazing as the guard is 6061T aluminum so Devcon epoxy did the trick. It's a hidden tang so Devcon is holding the whole thing together. The wood for the handle turned out pretty nice.
Reply:you really have a gift. it's nice to see somebody who is a master at his or her craft.
Reply:Your work is on par with a jewelers work.  It is really nice.I saw the last set of knives, and I forgot to ask.  Do you buy a "blank" blade and work from there, or do you also make the blade?"Any day above ground is a good day"http://www.farmersamm.com/
Reply:I grind my own blades and heat treat them. All I've posted pictures of have been made from wore out Nicholson files except two and those were made from a Lenox 14' lathe file. I found the Lenox to be a little harder than the Nicholson's with the same heat treat.Friend of mine owns a large machine shop and he gave me a bucket full of old Nicholson files with that one Lenox. I bought some 1095 steel recently just to try something different.
GMT+8, 2025-12-22 21:40 , Processed in 0.205329 second(s), 18 queries .
