查看: 13|回复: 0
can you identify what these are????
发表于 2021-9-1 00:15:51 | 显示全部楼层 |阅读模式
I got these 2 things out of my buddy's grandfather's barn and have no idea what they can be...they are very old...could anyone please help..thanks a bunch
Reply:The first look like a press.  It threads onto something and the screw is turned to sperate the items.  I have one similar for removing bicycle cranks from the spindle--the thread are mail however.
Reply:Maybe the other is a transmission for a lawn tractor.
Reply:scrap or another mans treasureslolololgot to love barn finds
Reply:1st one is a wheel puller for car with wood wheel like 1927 car.
Reply:If your camera has a flash, please use it.  More details of these objects would be visible.
Reply:The #2 item looks like a govenor to me check pic#4 those 3 dime size disks look like gov. weights and the disk on the same shaft looks like disc brake because on the lever it has a small pad and that lever is spring loaded       ANY MORE HELP    Bob sr.
Reply:Originally Posted by bobbowtieThe #2 item looks like a govenor to me check pic#4 those 3 dime size disks look like gov. weights and the disk on the same shaft looks like disc brake because on the lever it has a small pad and that lever is spring loaded       ANY MORE HELP    Bob sr.
Reply:beautiful piece ofclockwork...can  i cast a vote for  glurg in the best avatar contest?
Reply:Could we get a closeup of the name/wording on that side? Is there any such lettering on the other side?  Any patent dates shown?It's clearly a governor but for what? An elevator?  A mineshaft hoist? Lots of possibilities, I guess.
Reply:Well,....according to an old friend: .." Picture #1 is a wheel puller, picture #2 is a power unit out of an old Victrola spring powered record player,." John wouldn't say that if he weren't pretty sure; he's worked on lots of stuff over the decades. That would also make sense to me, as the power spring would be inside the drum unit.
GMT+8, 2025-12-22 21:34 , Processed in 0.089029 second(s), 18 queries .
