Infeed Chain Repair
发表于 2021-9-1 00:15:51 | 显示全部楼层 |阅读模式
Well We are part way through shut down at my place of work. Most of it was black dirty back braking work. Well today I had to fix up the infeed chain. This chain pulls the sawdust up into the infeed secion of the boiler. All I had to do was weld on some tabs that broke off during jams and replace some flights. The problem is that the tabs need to be welded on both side in order for them to take the beating. You will be able to tel from the pic's that this is not a easy job. And I thought other poeple got all the fun jobs.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:Looks like one of the more fun jobs.  You are not so "little" I'll trade ya, today I have to put a fuel pump in a truck that won't fit in my shop and its raining out.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Those pics remind me of working on the portable rock crushers. They also have tight spots repairs are needed in. Good pics.                                MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:I sure hope you have a lock on the power switch.WeldPro LS160PForce Cut LP80D
Reply:if it was easy everybody would do it.
Reply:Originally Posted by patrickpif it was easy everybody would do it.
Reply:I hope you had someone on hand with a fire extinguisher, especially given the sawdust everywhere!
Reply:Just looking at the crossbars makes my knees and front of my legs hurt.  That has to be a killer laying on those things for any time at all.It's not a miserable job on something that breaks regular........  It's job security "Any day above ground is a good day"http://www.farmersamm.com/
Reply:Miserable job??  naw!Member, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Miserable job??  naw! Just look at the smile on that face!  Anyone can tell he's happy, happy, happy!!    Member, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Hell if it was easy.They would have called someone else.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-22 21:40 , Processed in 0.091166 second(s), 18 queries .
