查看: 13|回复: 0
im confused
发表于 2021-9-1 00:14:28 | 显示全部楼层 |阅读模式
you can get aluminium stick welding electrodes which probly need flux yet you cant get flux cored aluminium wire for mig. can someone explain or better still, correct me?
Reply:yes thay make aluminum stick welding electrodes thay work so so i wont ever use then againChuckASME Pressure Vessel welder
Reply:Originally Posted by cheeseclipyou can get aluminium stick welding electrodes which probly need flux yet you cant get flux cored aluminium wire for mig. can someone explain or better still, correct me?
Reply:Im not sure I see why there is a need for flux core aluminum wire..?   Argon sheilding gas is readily available and works great for making clean aluminum welds.   The flux core steel wires I've used have been very spattery and dirty compared to the cleanliness and smooth puddle filling of solid wire and argon/co2 gas.   I dont think I'd be happy with the results of a flux cored aluminum weld if the wire was available.
Reply:flux core has the advantage of not being effected by air turbulence. I've had to use smaw aluminum electrodes when doing repairs outside sometimes, its a whole other learning curve with them compared to aluminum mig.
GMT+8, 2025-12-23 01:02 , Processed in 0.101191 second(s), 18 queries .
