Tennant Improvement
发表于 2021-9-1 00:14:21 | 显示全部楼层 |阅读模式
Been working on this the last two days. Been about 20* this week. Attached Images
Reply:More5 4 3 2 1 Attached Images
Reply:Is that just a covered entrance walkway or a drive-thru drop-off or ???Looks like you get an early start and/or work a little late.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Ha, the welding looks like the only warm part of that job. One guy strikes and arc and three put their hands around it. Long days in the cold take it out of a guy.
Reply:From the thread title I though you had a plan for getting better tennants!  Looks like a nifty little construction project!  20° aint so bad... cool enough to keep the sweat to a minimum.  -MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:We had 20 here today too.  The only problem was that it had this little symbol(  -  ) in front of it!Here is what I have so Far:Miller:Shop Master 300 A A/C D/CS 22a Wire FeederRFC-14 Tig PedalHF-251D High Freq. UnitProfax 250 A Mig GunVictor RegulatorsHarris:63-2 torch Cutting Attachment 49-3making home built tig cooler
Reply:BbbrrrrrrrrrrrA butterfly without wings, is just an ugly bug
Reply:Looks like a cold miserable job"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Looks like you get an early start and/or work a little late.No just working in Alaska a few days before the winter equinox.  Today we had 5h 27m of daylightTomorrow will be 0m 14s shorter.We started at 8am working till 4:30pm.
Reply:I think if it was that cold where I am I would choke someone... It was in the 70s here yesterday.Mike 93 YJwww.moabjeeper.com
Reply:Originally Posted by Fat BastardLooks like you get an early start and/or work a little late.No just working in Alaska a few days before the winter equinox.  Today we had 5h 27m of daylightTomorrow will be 0m 14s shorter.We started at 8am working till 4:30pm.
GMT+8, 2025-12-23 01:00 , Processed in 0.096108 second(s), 18 queries .
