Yard Trailer
发表于 2021-9-1 00:11:18 | 显示全部楼层 |阅读模式
I’m building a small yard trailer. Well when I started it was going to be a lot smaller. I’m using 1 ½ x 14 gage tube and 2x2 x 3/16 angle flux core with a Lincoln 175 HD 240 watt welder. All the materials are left over from other jobs and the only thing I have to pay for is wire, wheels, and beer (lots of beer). I figure it will cost me around 60$ when all is done. Attached ImagesI carry guns because cops are too heavy. .. ..-.   -.-- --- ..-   - .... .. -. -.-   .... .- .-. -..   . -. --- ..- --. ....   -.-- --- ..-   -.-. .- -.   ..-. .. --. ..- .-. .   .- -. -.-- - .... .. -. --.   --- ..- -
Reply:I' have a lot left to do and I'll keep you posted. Attached ImagesI carry guns because cops are too heavy. .. ..-.   -.-- --- ..-   - .... .. -. -.-   .... .- .-. -..   . -. --- ..- --. ....   -.-- --- ..-   -.-. .- -.   ..-. .. --. ..- .-. .   .- -. -.-- - .... .. -. --.   --- ..- -
Reply:Well it will certainly be better built than the crap they sell in stores. Put some wide tires on it to help stabilize it! I got a free tow behind cart with my cub cadet garden tractor - the tires were too small it it  became to unstable on hills or if you had a heavy loadLast edited by specter; 04-08-2009 at 10:29 AM.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Looks like it ought to be sturdy enough when done!Are you making this with a tilt bed for dumping?I would watch welding near that kindling pile, a weld spark could smolder there and make you have an exciting night, and not the pleasurable kind either! #1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:It’s very sturdy and heavy. I will be putting wide tires or just duel it out I don’t know yet. Yes I need to clean up a little, ok a lot. I know better but some how the Lincoln just takes over my mind and tells me just weld, Just weld. I carry guns because cops are too heavy. .. ..-.   -.-- --- ..-   - .... .. -. -.-   .... .- .-. -..   . -. --- ..- --. ....   -.-- --- ..-   -.-. .- -.   ..-. .. --. ..- .-. .   .- -. -.-- - .... .. -. --.   --- ..- -
GMT+8, 2025-12-23 07:36 , Processed in 0.094958 second(s), 18 queries .
