Wire Size
发表于 2021-9-1 00:09:58 | 显示全部楼层 |阅读模式
New To WeldingIm Using A Millermatic 210Im Welding 1-1/2" Square Tubing To ItselfTo Make A Stand For My Neighbors GrillThe Chart In The Owners Manual Says I Could Use .023 Or .030With Different SettingsIs There  An Advantage With One Over The OtherThanks To All Who Reply
Reply:Its more what you are going to use most of the time.  .023 is kind of small for a 210 amp welder.  I would go with .030 or even .035.  What else do you plan to weld?DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:I Have Both Size Wires .023 And .030But My Question Is Is One Going To Be A Stronger Weld Than The OtherBecause The Welds Look Just The Same Side By SideThanks Again
Reply:First question. What is the wall thickness of the tube you are welding at the moment..30 will work for probably everything you weld, assuming your a hobby welder.Patriot Performance AutoLincoln Power Mig 255CLincoln AC-225 StickVictor Journeyman O/AQuincy QT-5 Compressor
Reply:The Wall Thickness Is 1/8"But I Just Put The .023 In The GunAnd Was Wondering If Its Ok To UseIf There Is An Advantage With On Over The Other
Reply:Well for myself I rarely do sheet metal so I'd use .030 because it's already in my machine. I don't mess with .023 in unless it's 16 ga or thinner. But that's me.
Reply:Originally Posted by MYBOYDAVEThe Wall Thickness Is 1/8"But I Just Put The .023 In The GunAnd Was Wondering If Its Ok To UseIf There Is An Advantage With On Over The Other
Reply:.030" always seemed to be a fair amount more resistant to birdnesting than .023" IMO
Reply:Sandy Thanks For Answering My QuestionAlot Of Times In These ForumsSome People Answer Everything But The QuestionIm Not Complaining About The ResponsesId Rather Get Them Than NotThanks Again SandyAnd Everyone Else
GMT+8, 2025-12-23 11:04 , Processed in 0.064837 second(s), 18 queries .
