Wilton Bullet vise
发表于 2021-9-1 00:07:48 | 显示全部楼层 |阅读模式
Found a 5" Wilton Bullet vise for $75 needs one new jaw on it. Is it worth it i think so but dont know much about these besides you dont see them often.Equipment:Lincoln Ranger 8Lincoln Power Mig 255Miller Diversion 165Hypertherm Powermax 45Victor Pro Series Torch setTons of other shop supplies
Reply:considering that a new Wilton, depending on the model, runs from around $500 up to around $1200, I'd jump on it
Reply:I have a square wilton vise, always wanted the bullet style though.Chicks dig the bullet, definitely wouldn't think twice for $75 if it works.Semper FiJesus may have been a Carpenter, but his dad was a Millwright" A grinder and a can of paint, will make a welder what he aint' "I've done so much, with so little, for so long, that now I can do anything with nothing!
Reply:it is dated 1952Equipment:Lincoln Ranger 8Lincoln Power Mig 255Miller Diversion 165Hypertherm Powermax 45Victor Pro Series Torch setTons of other shop supplies
Reply:Doesn't matter, they are the top of the line vises in my opinion.I believe that is a 1st gen WiltonIf it clamps good and holds, it's worth it. Any cracks or weld repairs? If not I would still get it. If you don't, then don't. SimpleSemper FiJesus may have been a Carpenter, but his dad was a Millwright" A grinder and a can of paint, will make a welder what he aint' "I've done so much, with so little, for so long, that now I can do anything with nothing!
Reply:I plan on restoring this vise i will probably sand blast it or just wire brush it  But what is the best paint to use one a vise. I will probably have the jaws made at a local machine shop so i dont have to worry about them being wrong if i order them off the internet. Unless anybody knows of somewhere to order them for that specific model which i doubt you can do that considering it is so oldEquipment:Lincoln Ranger 8Lincoln Power Mig 255Miller Diversion 165Hypertherm Powermax 45Victor Pro Series Torch setTons of other shop supplies
Reply:Contact Wilton and you might be pleasantly surprised as they may still have replacements. I have three Wiltons, two from the '70s and a secondhand one I have no idea when was made but long ago. Replacement jaws are still available for them. If you are in an area where oil is produced I would check with one of the supply stores as they have always been available from that source for me.For what it's worth I consider Wilton's to be as good as any vice ever made.
Reply:i would jump on it with all fours. i have a giant azz columbian mounted on a stand bolted to the floor but my medium wilton bullet mounted on a drop hitch to my welding table takes the bulk of abuse as it has for the 35 years i have owned (used) been terrorizing it.  a friend has a newer one mounted on his truck that the handle is bent in an L shape. i have used 3' cheater pipes on mine and never bent the handle.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:I would paint it teal (medium blue-green) with a nice wrinkle finish. Semper FiJesus may have been a Carpenter, but his dad was a Millwright" A grinder and a can of paint, will make a welder what he aint' "I've done so much, with so little, for so long, that now I can do anything with nothing!
Reply:Originally Posted by skelley521I would paint it teal (medium blue-green) with a nice wrinkle finish.
Reply:What kind of paint will last the longest and be the best on the vise. I plan on just painting it gloss grey. Thats what most i have seen have been painted so figured thats what it was when it came out dont know.Equipment:Lincoln Ranger 8Lincoln Power Mig 255Miller Diversion 165Hypertherm Powermax 45Victor Pro Series Torch setTons of other shop supplies
Reply:Originally Posted by kyleb0789What kind of paint will last the longest and be the best on the vise. I plan on just painting it gloss grey. Thats what most i have seen have been painted so figured thats what it was when it came out dont know.
GMT+8, 2025-12-23 15:05 , Processed in 0.074292 second(s), 18 queries .
