Pictures of my first welds!
发表于 2021-9-1 00:03:22 | 显示全部楼层 |阅读模式
This is the result of 4 rods of 1/8 6011 on some 1/4 steel.  For size reference, the piece is 6" wide.  I just quickly went over them with a knotted brush on my grinder.  I realize they aren't completely clean.  Before I ran the beads I did go over the steel with a flap disc and got it mostly clean.  The top bead was my last rod and I had it set at 90 amps.  The second from bottom with the large crater at the end was set at 105 amps.  The second picture is a closer up of the top bead.  Please critique.
Reply:First time out..Looks good!Higher amp one is better..All in favor say "I"...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Aahhhhhhhhhhhhh!!!!!!!!!!!!!!!!!!       Just kidding... Thats not bad at all for the first time!AC or DC?Me!
Reply:Originally Posted by Me!Just kidding... Thats not bad at all for the first time!AC or DC?
Reply:You're well on the road to doing good welding with beads like that.    Keep working with those 6011's until you get better, then try a small box of 6013's.   A slightly shallower welding rod by the book but exterior variables can make it just as strong but a hell of a lot easier to weld and make pretty beads with.   6013 rods have never failed me one time.   Overhead welds with an AC crackerbox using 6013's.  Done it more than once.   I'm sure the book say's you can't.    You can.  Clean a good joint and get familiar with 6013's and see if ya don't see what I mean.
Reply:Looking good, especially for first time.
Reply:looks good .. I'll agree with zap... Keep burning them rods...
Reply:Lay one bead right up against the last so that the edge of the second bead is real close to the center of the first bead. A chunk of pipe is great for training you to make multiple, straight beads. For instance...I'm not saying for MY beads, but you WILL get better with enough practice!!!City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Those look good for the first time ever welding, better than mine with ac buzz box and damp rods (thats what I learned with).Keep at it and practice, practice, prac............ well you get it.Got anything in mind for a first project??G3miller... 225g, s32p, 250x, 304, 12vs, MSW41     victor o/a thermal dynamics cutmaster 50 lenco panel spotter        hobart hf-boxG3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
Reply:Originally Posted by G3farmsKeep at it and practice, practice, prac............ well you get it.Got anything in mind for a first project??G3
GMT+8, 2025-12-23 21:40 , Processed in 0.122690 second(s), 18 queries .
