arched top iron doors and stuff
发表于 2021-9-1 00:02:24 | 显示全部楼层 |阅读模式
20mm square solid, black matt powder coat. Heat colored copper under pulls clear coated. Frame bolted to rock will be boxed w/wood, as well ad double tube door frames. Ground sloped more than 2" in opening, so I did same to frames- looks square to me!Peter Attached Images
Reply:looks great
Reply:Originally Posted by ed maclooks great
Reply:Heck I like the steel meeting the rock like it does. Wood frame seems out of place. Are those spring loaded doors?
Reply:WOW! You should be very proud. I would love to be able to do work like that.
Reply:beautiful work man!Brian LeonardAppalachian Ironworks L.L.C.434 Long Branch Rd, Marshall, NC 28753828 649 9966828 702 [email protected]
Reply:Originally Posted by SandyHeck I like the steel meeting the rock like it does. Wood frame seems out of place. Decorator wanted wood and iron, will get finished pics when done.Are those spring loaded doors?
Reply:Wow...  Great looking Gate.  Normally I find most gates a bit 'pretentious' and 'over-the-top' so to speak, but this one looks like it 'Always Belonged' there and is very natural looking.Beautiful....Cheers,/Jman...
Reply:Where are the drawbridge and watchtowers?  Nice gates.  I also think the stone and steel look just fine as-is.  The best laid schemes ... Gang oft agley ...
Reply:Originally Posted by jmanWow...  Great looking Gate.  Normally I find most gates a bit 'pretentious' and 'over-the-top' so to speak, but this one looks like it 'Always Belonged' there and is very natural looking.Beautiful....Cheers,/Jman...
GMT+8, 2025-12-23 21:45 , Processed in 0.084004 second(s), 18 queries .
