Beveling pipe
发表于 2021-9-1 00:02:10 | 显示全部楼层 |阅读模式
Anyone have simple ideas, plans for a pipe beveling set up for plasma cutter? input is appreciated!AEAD 200LE, Lincoln precision tig 185, Millermatic 251, Spectrum 625 extreme, Victor torch , Smithy 1220LTD. and  Do all C-4 band saw ,  Always adding.
Reply:a steady hand and a wrap around.
Reply:Only thing I can think of is an old gear reduction with a 4-jaw chuck mounted to it, and an arm to hold the torch, or if you could find a used rotary table. No easy way around it that won't cost some money.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:H&M pipe beveler and a machine torch for your plasma cutter.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:Are you just doing test coupons?
Reply:Originally Posted by farmallAre you just doing test coupons?
Reply:Lathe is the easiest.  A guy i know has a contract with East Bay Mud for doing their test coupons.   he sends them 200 at a time 6" pipes 7" long with bevels on one end with their root and land specs.   he does them all on a lathe.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-23 21:41 , Processed in 0.106100 second(s), 18 queries .
