sure way of sticking rod to workpiece
发表于 2021-8-31 23:59:12 | 显示全部楼层 |阅读模式
hi, i appreciate its an odd question but i was looking to use my dc stick welder rods to pull out a couple of dents in sheet metaldoes anyone know a sure way of sticking rod to workpiece 1st time every time?ive managed it a few times but when i actually try to do it intentionally theres no reliability to it. is it best to use rods whose flux is intact right upto the very end?thanks****diy alert****
Reply:You can turn the heat down about 20 to 30 amps lower than what you would normally use and hold the rod down on the metal without any movement. This will usually stick one nicely. A better way to do this may be to drill a hole in the metal and then stick a hook in it and pull the dent out. Then you can weld up the hole and grind it off.
Reply:I had a 5 pound box of 3/32 6010 Radnor rod that stuck almost every time unless you had the amperage up really high. Then it splattered like all hell. I used it up doing tack welds. Thank God it's gone.Joewww.CummingsHauling.com
Reply:Just get someone who has never touched a welder and let them practice on it. . Will stick every time at first. --Gol'
Reply:Originally Posted by joethemechanicI had a 5 pound box of 3/32 6010 Radnor rod that stuck almost every time unless you had the amperage up really high. Then it splattered like all hell. I used it up doing tack welds. Thank God it's gone.
Reply:weld a bolt to the dent and make yourself a slide hammer, it dont have to be anything fancy, but if you want to just make it stick on its own, knock the flux off the rod with the amps low, its a sure fire way to make it stick good everytime.Nothing Ever Got Done By Quitting, Never Give Up.
Reply:I can get them stuck with the best of them..That's why its called "Stick Welding"......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Hold the end of the rod to the sheetmetal, then touch your "stinger" to the other end of it for just a second, and remove it.  The rod will stick to the basemetal, but not to the brass in the stinger.
Reply:Originally Posted by EngloidHold the end of the rod to the sheetmetal, then touch your "stinger" to the other end of it for just a second, and remove it.  The rod will stick to the basemetal, but not to the brass in the stinger.
Reply:You could mig the rod in place! I've done that! City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by roverfani actually tried this and the other way round, by holding stinger and rod to workpiece and briefly touching the earth clam to metal but both dont actually work. ive found that it tries to weld where the contact is made, so now ive got two slight discolourations each to my stinger and earth clamp when i tested each method twice.
Reply:Use BlueSheild 7018, it sucks, I mean sticksNothing Ever Got Done By Quitting, Never Give Up.
Reply:Originally Posted by EngloidIf it didn't work, you did it wrong.  I've done this for over 20 years.  I know it's a ghetto fix, but it also works for drying damp rods, by preheating them for a second or two.
Reply:Originally Posted by roverfanthanks engloid, i'll try that again adding some courage next time to hold down longer.
Reply:Get some atom arc 7018, that will do it. Well more times than not anyway, lmao.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:I'll agree about the atom(no) arc...
Reply:I'll third that about the Atom arcs.....   Also if you knock the flux off the end of the rod it will make it easier to stick as well.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
GMT+8, 2025-12-24 03:01 , Processed in 0.224050 second(s), 18 queries .
