110 VOLT 20 AMP Power cord?
发表于 2021-8-31 23:54:44 | 显示全部楼层 |阅读模式
I want to buy a 20 amp 110 power cord but it all the one I look at are only rate for 12-15 amps max? My 80amp 110 HF Arc welder says it need a 20 amp cord for the power cord? I like to do some job over at a buddy's house but the outlet is a good 15 to 20 feed away as I don't want to welded on his nice wood deck. I just don't want to keep kicking the breaker or set the cord on fire or maybe not be able to get all the power I need? Or is the 15amp cord just fine for once in a while use???
Reply:any cord in a 12 -10 awg would work judt fineLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Yellow Jacket brand Water resistant 10-3 50ft  Lowes/ Home Depot $50-$60Beer has food value, Food has no beer value
Reply:Actually the amp rating on cords has to do with what's considered continuous duty. You won't be doing anything continuous duty. If you're worried about voltage drop, that's another issue. However since you don't know the first portion of his circuit build from the breaker to the outlet you're last 15 feet of cord probably will have little effect on the overall circuit. Plus a 20 amp cord on a 15 amp breaker isn't going to aid anything."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:I find the larger the cord, the better the chance of making a quality weld. It just let's it have all the juice it wants. It is worth the money to get as big as you can afford. Sent from my BlackBerry 9650 using TapatalkCERTIFICATIONS:7018M- H.V.O10718M- H.V.O11018M- H.V.O9N10- H.V.O71T-1-HYM- H.O.V100S1 PULSE ARC 0,035- H.O.V100S1 PULSE ARC 0.045- H.O.VER70S-3 PULSE ARC 0.035 H.O.VER70S-3 PULSE ARC 0.045 H.O.VER5554- H.O.V
GMT+8, 2025-12-24 10:18 , Processed in 0.070182 second(s), 18 queries .
