another air compressor bomb
发表于 2021-8-31 23:54:44 | 显示全部楼层 |阅读模式
found this on my local craigslist http://yuma.craigslist.org/tls/2937201577.html350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:An expensive one even.  Who's he kidding?My name's not Jim....
Reply:A Home built air compressor.Just think about those words together. Does anybody remember the psi rating of water heater style copper flex?
Reply:Well at least he has it chained down so that when it goes BOOM it will not go AS far. A "Home Built" air compressor........... jrw159
Reply:I noticed the copper flex (thought it was gas line- like for a stove) But the first thing I saw was the line of what looks like rivets ( near the bottom front) and the fact he has turned the tank so the drain is on the front (and so the copper flex reaches) and the rewelded mounting plate. Way too scary but I wish I lived closer ,I'd like to go look at it.Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:Don't see a problem with the welds.All compressor assemblies are welded.The line from the compressor block to the tank will fail pretty much as a rubber airline will fail, if it fails.  I've never used this type of tubing, but have regularly used flexible copper refrigerant tubing for relief/shutoff switches. I don't see a governor/relief valve, but then I'm not familiar with engine drive compressors.Exactly why will it be a "bomb"?"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Not to mention running the engine indoor's...Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Originally Posted by MarkNotMarcA Home built air compressor.Just think about those words together.
Reply:I don't see a pressure switch to shut the engine off. That would definitely be a quick way to remove the siding from your garage.
Reply:Originally Posted by farmersammDon't see a problem with the welds.All compressor assemblies are welded.Exactly why will it be a "bomb"?
Reply:Originally Posted by GrinshaI don't see a pressure switch to shut the engine off. That would definitely be a quick way to remove the siding from your garage.
Reply:For $1200 you could just go buy a new one and not mess with this junk that he wants to get rid of.
Reply:there is a pressure relief just down from the compressor. guess he's just gonna let it run till the pop off goes then when pressure drops and it closes he is back in business."Liberalism is a mental disorder" Dr. Savage
Reply:Originally Posted by CharleyhorseWell, with gas engine driven compressors, the engine doesn't shut off, there's a clutch that disengages the engine from the compressor, and the engine throttles down.  I don't see any tubing or pipes anywhere going to any mechanism that will govern the pressure in the tank, and I don't see an overpressure relief valve. There is just an air gauge attached at the tank air outlet.  Maybe the way you use this compressor is to watch the gauge and shut the thing down manually when you hit max pressure, or maybe the engine just stalls on its own after you hit 200 psi or something.  Looks really safe, eh? I wonder how much legal liability this guy is exposing himself too if he actually sells this bomb to somebody dumb enough to buy it.
Reply:You guys are makin a mountian outta mole hill here, I mean, what could POSSIBLY go wrong? [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Originally Posted by Charleyhorse I wonder how much legal liability this guy is exposing himself too if he actually sells this bomb to somebody dumb enough to buy it.
GMT+8, 2025-12-24 10:19 , Processed in 0.070280 second(s), 18 queries .
