Looking for 7 inch tubing/pipe
发表于 2021-8-31 23:54:42 | 显示全部楼层 |阅读模式
Looking for 7 inch dia, .0625 to .1250 wall thickness. Can anyone point me in the right direction?-----------------------------------------------------ThanksKenVan Ness BuildersboocrewproductionMidnight Haunters SocietyBeyond Midnight
Reply:Originally Posted by Boo Crew ProductionLooking for 7 inch dia, .0625 to .1250 wall thickness. Can anyone point me in the right direction?
Reply:I am sorry, DUH... Yea I guess that would have been wise huh? I need it to be steel. To start out with I'll need about 4 feet to build a couple prototypes. Thanks in advance.Ken-----------------------------------------------------ThanksKenVan Ness BuildersboocrewproductionMidnight Haunters SocietyBeyond Midnight
Reply:Have you tried your local steel supplier?Have we all gone mad?
Reply:Try EMJ (Earle M Jorgensen)http://www.emjmetals.com/Default.aspxIf it's not available and you'll only need 4' sections then you might consider having the pieces rolled for you but I don't know if that will work for your application.http://all-a-cart.comWelding Cart Kits and accessories
Reply:Originally Posted by ZTFabIf it's not available and you'll only need 4' sections then you might consider having the pieces rolled for you but I don't know if that will work for your application.
Reply:Originally Posted by BoostinjdmX2.  Either that or make your prototype fit an easier to get size tube.
Reply:Originally Posted by ZTFabUnfortunately, sometimes that's not an option. I don't know what Ken is working on but I just got done making some prototypes for the wind power industry and I needed some 7" x .250" 6061-T6 tubing and wasn't able to deviate from that based on the requirements of the design.Only two sources (EMJ and Tube Service) had it on the West Coast....at a cool $110/ft.
Reply:Just had a look in my little black book.Closest is 6"  1/8 wall pipe, which has an O.D. of 6.625"Nothing else even close in standard size.You are going to have to get some sheet steel rolled up on slip rollers and welded, not that difficult.Cheers,  Tony._________________________________Transmig 310 + Argoshield LightOxy acetyleneOxy propanePrehistoric stick welder_________________________________
Reply:Originally Posted by BoostinjdmI did say either/or.
Reply:Originally Posted by WarpspeedJust had a look in my little black book.Closest is 6"  1/8 wall pipe, which has an O.D. of 6.625"Nothing else even close in standard size.You are going to have to get some sheet steel rolled up on slip rollers and welded, not that difficult.
Reply:Also can try metals4u.com/ There Based in Texas, But I'm sure they can ship to you, at 4' it will fit on UPS Ground trucks.
Reply:Originally Posted by sn0border88That's pipe, tube is a whole different animal as far as sizes go.  7" .0625/.125 shouldn't be too hard to find at all.
GMT+8, 2025-12-24 10:19 , Processed in 0.087638 second(s), 18 queries .
