A couple of cheater lens questions
发表于 2021-8-31 23:46:48 | 显示全部楼层 |阅读模式
I have banged around in a couple of lens threads but did not see the answer to my question.  Is a 3.00 cheater lens going to be about the same as my 3.00 cheater glasses?And a quick search shows that most fall in the 2" x 4.25" range with some at 2 x 4.  Is this a standard size?  I really hate wearing glasses under the hood.  They never seem to be in the right place.
Reply:Yes the 3.00 is the same as the 3.00 reading glasses. And that is the standard size.I use a 2.00 in my helmet as that is what my bifocals are so I can still wear my glasses and see without tilting my head to see the weld bead. I buy the glass ones they cost more but are a lot clearer.www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Thanks.  I have progressive lenses and it's proving to be a real PIA.
Reply:Cheater will be the same as your reading glasses as long as the distance from cheater to the job is the same length as you hold the newspaper from your reading glasse, I;E I use 2.5 for reading but only a 2 for looking at computer screen, because my eye distance to the screen is longer than my eye to the newspaper.Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:I go for the glass ones also but check the fit in your hood first,on some of the newer auto dark hoods the clips won't allow for the extra thickness of the glass cheaters.Trailblazer 302Hobart Stickmate AC/DCLincoln SP 135 TSmith torchSpoolmatic 30A
GMT+8, 2025-12-25 00:24 , Processed in 0.090061 second(s), 18 queries .
