newb question
发表于 2021-8-31 23:38:15 | 显示全部楼层 |阅读模式
howdy everyone got a quick newb question i have a hobart handler 140 and i want to start welding Aluminium and the spool gun for the hobart is like 475 dollars from the welding supply store but the miller spoolmate 100 series for the Millermatic 140 is only 175 dollars now the question is will the spoolmate work with a hobart thanks gents Bruce
Reply:I would wait and see what responses you get because I believe your machine is under powered and will have limitations.  You might need to upgrade your welder.
Reply:X2 what jay says when welding alumium its ideal to run it in spray or globular transfer and them modes are out of reach for the 140 handler and even if you could weld lets say 16-18g you would be workign against the duty cycle but i guess it would be possibleLast edited by Bozzza; 04-02-2010 at 06:41 PM.Cigweld Transmig 265seBoc 140amp StickBoss 200amp AC/DC TIGLincoln Electric Invertec V260-S
Reply:i see thanks for the imput
Reply:Originally Posted by BozzzaX2 what jay says when welding alumium its ideal to run it in spray or globular transfer and them modes are out of reach for the 140 handler and even if you could weld lets say 16-18g you would be workign against the duty cycle but i guess it would be possible
Reply:Originally Posted by nrhmarine7hey the "spray or globular transfer" could you explain that to me thanks alot man i am still learning
Reply:Originally Posted by nrhmarine7howdy everyone got a quick newb question i have a hobart handler 140 and i want to start welding Aluminium and the spool gun for the hobart is like 475 dollars from the welding supply store but the miller spoolmate 100 series for the Millermatic 140 is only 175 dollars now the question is will the spoolmate work with a hobart thanks gents Bruce
Reply:Hobart handler 210 at Northern Tool $899, includes regular mig gun and 10 foot spoolgun.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
GMT+8, 2025-12-25 20:34 , Processed in 0.146036 second(s), 18 queries .
